K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Everything is possible if we work together!
not sure, but it will take some time.
i have much things on my head right now.
but im still working hard in here;pEverything is possible if we work together!
i will upload new modules package soon.Everything is possible if we work together!
Great Rom Lewy, everything works awesome but since installing the rom i lost all sound to analog output is there a fix?
Originally posted by lewy20041 View PostThis firmware is based on the latest one relised by geekbuying.com
I want to thanks geekbuying for donateing me this nice hardware,
i have to say that this box in my opinion is best choice of tv boxes and sticks for now.
Its have analog tv out, hdmi, 2Xfull size usb, 1xmicro usb otg, spdif, audio jack, rj45 and micro sd slot.
You can buy it here:
GeekBuying.com
!For now only for K-R42 without bluetooth!
My website:
http://www.apkfreak.com
Changelog:
Beta
(some bugs may be present)
(after flash and first boot up, cut the power from device to get sound{one time})
v1.2.2
-tincore updated to latest ver. (performance boost for games)
-new kernels 720p/1080p for K-R42, 40% like performance boost
-video stutter fixed
-1920x1080-24hz
-download xbmc under settings>special (download the latest nightles with hw accel)
-usb adio fixed
-ir remote mappings fixed
v1.2.1
-all futures of 1.2.0
-firmware migration (!there might be some bugs due to hevy changes, please post your findings!)
-new shutdown menu
-power off working as it should
-new base firmware (latest minix firmware)
-fixed setting/firmwork-res strings
-screenshot button can be turned off/on in settings (!change location of screenshot to sdcard!)
-autohide statusbar option in settings>display
-new 720p kernel to prevent reboots (from "ugoos ut1")
-alot fixes, tweaks etc.
Stable
(last ver based on stock k-r42 rom)
v1.2.0 Final
-K-R42 720p/1080p
-root
-spoofed as Galaxy SIII
-gamepad button on statusbar opens "Tincore Key Mapper" (you can play games like bad pieggies with mouse)
-build.prop tweaks
-gameloft fix
-2gb app space
-changed bootanimation
-deleted usles apps
-better webcam support (logitech webcams like c525 wasnt working before, now it works like a charm)
-bootsound suport (put any .mp3 into system/media and rename it to android_audio.mp3 it will be played at bootanimation screen.)
-auto install advancedsettings.xml for smooth 1080p videa playback in XBMC
-Default launcher option under HFW settings>Special (Chouse which launcher you want to use as default)
-nfs support
-init.d support
-added HFW version under settings>about device
-added some nice apps:
*ES Explorer (ver. before layaut change)
*Wallbase
*Youtube for GTV 1.6 (due to login problems on 1.7.1)
-new settings (HFW Settings)
*Special
*Performance (you can change CPU clocks)
*Equalizer (need some testing)
*SuperSU (now it wil show here insted of app drawer)
*Terminal (//-//-//-)
*Xbmc Installer (//-//-//-)
-unlocked hiden options:
*Bluetooth
*Accessibility
-new modules:
*ntfs.ko added
*md4.ko
*pl2303.ko
*crc-itu-t.ko
*isofs.ko
*cdrom.ko
*udf.ko
*isofs.ko
*btusb.ko
*tun.ko
*virtual touchscreen.ko (720p)
-some visual changes
-modules package [provided with the rom package]
-disabled hdmi check for apps like "Xfinity, HBO GO"
-new visual (system bar etc.)
-power button on system bar
-clean home screen from usles shourtcats and widgets
-new wallpaper
-ic_sysbar_highlight changed to cyan
-ic_sysbar_lights_out_dot changed to transparent (no dots on status bar when waching movie on mx player etc.)
-deleted search bar from home
Beta:
v1.2.2
Dev-Host 720p
Dev-Host 1080p
Stable:
v1.2.0 Final
Devhost 720p
Devhost 1080p
Regards
Lewy20041
Thanks go to:
leolas (for his help whenever i need)
phjanderson (kernels for t428)
hoabycsr (kernels for mk908)
FinlessBob (kernel pach for K-R42)
Wasser (kernels for K-R42)
Any chance the new ROM will be Android 4.3? Asking as this opens for Netflix in HD and SuperHD
Off topic: You guys should try this version of Netflix:
I'm using the maximum 3850 kbps version and the quality is way better than the official Netflix appLast edited by Varming; 02 September 2013, 18:31.
Originally posted by Varming View PostAny chance the new ROM will be Android 4.3? Asking as this opens for Netflix in HD and SuperHD
Originally posted by Varming View PostPersonally I will strongly recommend trying the 1.2.2 it works so much better on my box. The 1.2.0 had several slowdowns and fc's here where the 1.2.2 is a lot more solid and seems to be a lot better at playing back video. I'm using the 720p kernel as I use the box with my 26" bedroom TV. Almost too bad as the picture is also great on my 42" livingroom plasma
Originally posted by Finless View PostI cant seem to download this from rapidshare. Can someone please provide a mirror?
There are currently 5765 users online. 3 members and 5762 guests.
