Only problem with USB which I encountered is when the device with before mentioned firmware version is put into suspend mode by pressing power button on remote control or on top of enclosure. Then after sometime USB power down till next reboot. After power on when you see X (-man) Lewy20041 logo there shouldn't be such problem.
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by Knario View Post
Only problem with USB which I encountered is when the device with before mentioned firmware version is put into suspend mode by pressing power button on remote control or on top of enclosure. Then after sometime USB power down till next reboot. After power on when you see X (-man) Lewy20041 logo there shouldn't be such problem.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by pes1313 View Postreflash the k-r42 without problems on windows 8
I read somewhere about problems with Realtek OTG Driver on Windows 8 64 bit but it might be not entirely true.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostDo you have 32 or 64 bit version?
I read somewhere about problems with Realtek OTG Driver on Windows 8 64 bit but it might be not entirely true.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Originally posted by Gormar View PostThese keyboard and mouse are wired or wireless?
Only problem with USB which I encountered is when the device with before mentioned firmware...
USB ports operate as if they recognize external hard drives...
The combo keyboard/mouse are wireless. That problem comments if I could find it, but I have not worked since I did not recognize from the start. The device is plug and play and with previous versions to 2.0.0 works.
If I use Usb diagnostic applications such as USB host controller if it detects the device as a keyboard/mouse but I can not make it work. The program says that the S3C USB Host driver not found in all HFW by lewy20041 versions.
Can you fix it in an upcoming update?
Could you tell me how to proceed to work?
thanksLast edited by Knario; 03 November 2013, 17:02.
Originally posted by wasser View Posthi all
i uploaded new k-r42 kernel. Please download and test if it fixes the sleep/wakeup issue from suspend state. I have tested it on my k-r42 box. It works fine for me.
Please give me feedbacks, thanks!
http://d-h.st/v1v
EDIT: other than that, the sleep feature works. i press the button, screen goes off, LED goes red and after pressing the button again or pressing any button on my BT keyboard, it powers back on.
Originally posted by curlyboi View Postcompletely broke my resolution. i have a 720p projector and i can only see a part of the whole image (but i still have selected 720p mode). i have also an old tv connected thru the tv-out and i can see even smaller portion of the picture there (aka the tv-out is a crop of the hdmi picture).
In my case, sleep function still not works. After wakeup wifi and wireless mouse not working, but remote controller is fine.
Any news about sdk2.0 on this device?
Originally posted by rjtm View PostI try the kernel, display was shifted by default setting. But you can set screen scaling to max, it will fix shift issue.
Originally posted by digger View PostHi wasser! I'm glad to see your interest about issue with V2.1 new revision of CS918(w/o BT).
What detailed information would you like to be provided with? Will it be enough if I make some pictures of my V2.1 board or write the list of onboard chips? I can try also to extract kernel.img from stock firmware or provide you with the link where you can download full stock firmware image from. Please tell all you need and I'll do all my best so as to help you to help us.
2 pictures of your box where i can see the names of the chips
thanks
Originally posted by wasser View Postwifi and wireless keyboard works fine for me after wakeip, have you tested the latest kernel http://d-h.st/v1v
After tried this kernel, both 1080p and 720p mode all had shifed issue, if the screen scale not set to max. Scale did not take any effect at all, but only shift the screen, when set to max the screen shift to the right position. Not like version 2.0.4, with this version the desktop is 720p and scaling to 1080p when display. But scaling did works! By the way, my device is CS918.
Foto k-r42 v2.1
thanks
Last edited by pes1313; 05 November 2013, 04:33.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
thank you very much.K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
In: original controler/mini keyboard trackball controler wifi
XBMC Nightly build v13
Hello, after flashing lewy roms (i have tried 1.20, 2.03, just xbmc, even that rooted version of factory rom). On all of them i had same problem. Ethernet not working, sometimes device receives ip adress but it's slow and most of the times dont receive ip adress at all. What is strange, even my usb to ethernet adapter which i have used with old mk808 is not working. Device name is k-r42 from geekbuying. Is there solution for my problem?
@gsavicic. Give us something more to think about.
Output from command: "busybox ifconfig eth0" would be a good start.
Besides. Did you disabled WiFi in Settings?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 1610 users online. 2 members and 1608 guests.
