Other difference is probably that I set "fixed" MAC adress on ethernet interface early on boot process by /etc/init.d script.
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by michael2t View Post
Other difference is probably that I set "fixed" MAC adress on ethernet interface early on boot process by /etc/init.d script.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hello Gormar
Hello Gormar,
I am using 2.0.4 with out mods just stock Lewy 2.0.4
and Yes I am using Your Mac Address Fix as Well. Just as You showed me ...
01SETMAC
#!/system/bin/sh
ip link set eth0 down
ip link set eth0 address f6:a1:58:6f:d7:bb
ip link set eth0 up
As You have seen my issue .... already posted
Where are You putting it ... ??? In a Different Place ???
Are You NOT using the Latest Kernel Lewy / Wasser released ?
Michael T.
Originally posted by Gormar View PostWhich wasser's kernel do you use on your K-R42? Mine is from 19th September.
Other difference is probably that I set "fixed" MAC adress on ethernet interface early on boot process by /etc/init.d script.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Awful WiFi
Hi I received my TR42 yesterday,and I have a serious problem with my WiFi,it has terrible range,i get only one bar just 3.5 meters away from the router.So can somebody tell me how was WiFi when you received your BOX and you where using the original firmware?
Please answer I`m extremely worried and i don`t know what to do
I`m terrified the hardware is the problem.
BTW:I`m using the original firmware
Thanks in advance
Have a great dayLast edited by dinaxe; 11 October 2013, 18:49.
T-R42 Wifi dinaxe
Hello ...dinaxe
I never tested any thing until I load the NEW firmware From Lewy and Wasser...
I am Sorry ... So I can NOT tell You about the Stock Firmware ...
As I do NOT normally use Wifi ... I have been working on the NEW Firmware Roms so ... Everyone Had told me the two units were compatible but that is not the case ... There is a very big difference in Ethernet and Wifi / Bluetooth Chips in the T-r42 than in the K-R42
You Should Try some different Channels and Load the Free Wifi Analyzer from the Google Play Store... At least You would Know what the Real Signal Strength is ?
Lots of Times it is about the channel You have Your Router / Player set
to ... Check it out with the Wifi Analyzer ...
Bars really do NOT tell me any thing ... My K-R42 tests are -43 to -45 dBm
and My T-R42 test out at -40 to -42 dBm ... both on the same channel ...
My Tests are On Channel 1 ....
Most routers are set to Auto By default for the Channels Change and Try each channel to See which one works best for You ... I alway reboot My router after I change the channel ... Some times it is about Your Neighbors all being on the same channel and Washing out Your Wifi signal ...
Good Luck
Michael T.
Originally posted by wasser View Postplease download my new t-r42 firmware which i uploaded yesterday. It includes my new CWM recovery with remote support, it should work for t-r42 and k-r42
Do you or anyone know if this fixes the stock remote for the CS918 too?
tx
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by michael2t View PostAre You NOT using the Latest Kernel Lewy / Wasser released ?
But in Settings -> About Device it prints HFW 2.0.2. Which is impossible since I can use "Switch resolution".RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
To clarify what I think is the current position.
If I flash the new Wasser Kernel on a Lewy 2.04 ROM, that will work for both the K-R42 and T-R42?
Will this combination still allow the switch between 1080p kernel and 720p that was introduced in 2.03?
@PMbluesmanuk.
If you flash HFW v2.0.4 on both devices and then new wasser's kernel for T-R42 then you are set.
If you also want to switch resolutions then remember to place these new kernels into /system/preinstall and overwrite 720p.img and 1080p.img with adequate images. This is only necessary for T-R42 device.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
I did the switch resolution thing after replaced with Wasser's two new kernels (1080p & 720p) into /system/preinstall and somehow the firmware version changed from 2.0.4 to 2.0.2. Anyone noticed this?
Originally posted by xatang2013 View PostI did the switch resolution thing after replaced with Wasser's two new kernels (1080p & 720p) into /system/preinstall and somehow the firmware version changed from 2.0.4 to 2.0.2. Anyone noticed this?.
If you also want to switch resolutions then remember to place these new kernels into /system/preinstall and overwrite 720p.img and 1080p.img with adequate images. This is only necessary for T-R42 device.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by Gormar View PostThen there is a culprit. Lewy20041 forgot to edit these little prop files. But "changing" displayed version is as easy as editing /system/build.prop file line: ro.vendor.sw.version=HFW 2.0.2 to something more truthful. But don't be cocky by changing it to for expample HFW 2.0.99.
i forgot to change it.Everything is possible if we work together!
Just got a k-r42 (MK888B) box and finally got it rooted. Does this firmware still only support non-bluetooth devices? Can anyone tell me if Hulu Plus is working with this firmware? Does the remote work with this firmware? Thanks! (My Device: http://www.aliexpress.com/item/MK888...331527250.html)
Originally posted by michael2t View PostHey Lewy...
Is there any way I can Put command in startup script to lower Volume of Boot Animation Sound ...
I like the sound Just NOT full volume ...
Michael T.
[edit]:: Audacity, an Open Source Audio Editor, requires LAME MP3 encoder (external library) for writing .mp3 files with --> instructions to install here <--
There are currently 1481 users online. 2 members and 1479 guests.
