it is a bug in firmware. atm i have no idea how to fix. need to investigate
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by michael2t View PostHello Wasser,
Are You going to Help Rebuild the kernal to work with the NEW Wifi/bluetooth Chip used in the
T-R42 System as I have one and am hoping to get a new firmware version that works with the
player ... as the current version does not... When the wifi errors it kills all networking both the wired ethernet and the wifi/bluetooth ...
Thanks In advance for all of Your hard work ...
Michael T.
What do You NEED ???
Hello Wasser,
What do You need ??
I screwed Up my t-r42 by loading the firmware from Lewy2004 as I thought the to players were
compaible ... I am NOT the Only foolish one to do this and Now there are alot of people with players
that do NOT work because I was so excited to Have it I did NOT back it up before Reflashing ...
But, Please tell me if there is some thing I can Do to Help ??
I can Take it apart and take a picture of the PCB if You NEED me to??
Michael T.
Originally posted by wasser View Posti need more infos about wifi/bluetooth in t-r42 to make it workingLast edited by michael2t; 08 October 2013, 21:04.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
What do You need ??
Michael T.
All Networking Dead
Hello Wasser,
Because I loaded Lewy2004 firmware all My Networking is DEAD ...
I am Sorry ... I can NOT turn on Ethernet or Wireless or Bluetooth they are All
Dead Because I Loaded Lewys Firmware ...
I am Sorry ...
Michael T.
Originally posted by wasser View Posti need the output from dmesg with wifi enable from t-r42 with stock firmware3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Stock Firmware From Eric
Hello Lewy,
Can You get Eric to Post the Stock Firmware for the T-R42 ...
Please tell him I do NOT care if it is buggy ...
Thanks In advance ...
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by michael2t View Postall My Networking is DEAD ...I am Sorry ... I can NOT turn on Ethernet or Wireless or Bluetooth they are All Dead
IMHO only in one case LAN wouldn't work on T-R42 box with K-R42 firmware. When designers changed routing on the PCB from default GPIO assigned as RMII which is rather implausible. Even use of different PHY LAN chip shouldn't have big impact on LAN functions.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Gormar
Hello Gormar,
You ask ask all of the Others In the T-R42 Thread we all have the same issue ...
I am not the only one ...
No Wifi , NO Bluetooth and NO Ethernet ...
And that was With The Bluetooth and Wifi Off ...
Here is a Link to The PHoto of the PCB it is very different from that of the K-r42
Michael T.
Originally posted by Gormar View PostIt's almost impossible that LAN isn't working. Do not forget to disable WiFi in Settings because even if WLAN doesn't work it has precedence before LAN. It was opposite case in earlier HFW versions (1.2.2).
IMHO only in one case LAN wouldn't work on T-R42 box with K-R42 firmware. When designers changed routing on the PCB from default GPIO assigned as RMII which is rather implausible. Even use of different PHY LAN chip shouldn't have big impact on LAN functions.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by michael2t View PostHere is a Link to The PHoto of the PCB it is very different from that of the K-r42
http://imageshack.us/photo/my-images/541/vxmm.jpg.
In this design they used USB to LAN solution rather than RMII LAN PHY and build-in into RK3188 VMAC device. Good thing is that you would get constant and real MAC address. But first you must at least load kernel module with driver for ASIX AX88772 USB to LAN device.
P.S. I haven't got much time now but I'm almost sure that I saw some external modules for wasser kernel and there was asix.ko among them. You need it to ride ASIX beast. Source: http://forum.xda-developers.com/show...61&postcount=2
Last edited by Gormar; 09 October 2013, 01:27.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Asix and Usbnet ko files
Hello Wasser,
Gormar, Thinks you have these to files in one of Your Kernels ...
Could You please check as I need them to get my T-R42 running again
located in the /system/lib/modules
usbnet.ko
asix.ko
Could You please Upload these files and post a link if You Have them ??
thanks in advance
Michael T.
Everything is possible if we work together!
Hello Wasser
Hello Wasser,
The NEW Kernel loaded ...
I have Wired ethernet again ...
But I can NOT get the Wifi or Bluetooth to turn on ...
Is there anything I can Do to Help ?
Michael T.
Originally posted by wasser View Posti uploaded new kernel for t-r42. t-r42 owners plese test and report if wifi and ethernet work.
http://d-h.st/ool3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
The NEW Kernel load fine ...
Michael T.
please ignore bluetooth atm.
thanks
Here is The ifconfig Out
Hello Wasser,
Here is the BusyBox Ifconfig
Code:busybox ifconfig eth0 Link encap:Ethernet HWaddr F6:A1:58:6F:D7:BB inet addr:192.168.0.119 Bcast:192.168.0.255 Mask:255.255.255.0 inet6 addr: fe80::f4a1:58ff:fe6f:d7bb/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:620 errors:0 dropped:0 overruns:0 frame:0 TX packets:136 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:34552 (33.7 KiB) TX bytes:13894 (13.5 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Wifi Will NOT turn ON even after I turn off Wired Ethernet and Neither will Bluetooth
I will Do dmesg Next But Neither Wifi or Bluetooth will turn on ?
There are currently 6838 users online. 2 members and 6836 guests.
