K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by xatang2013 View Post
How do I apply this new kernel for my T-R42 to see if wifi and ethernet are fixed? Thanks Wasser
I recommend this kernel: http://www.freaktab.com/showthread.p...l=1#post102256 where LAN is operational. Other has more debuging options enabled.
And if you have HFW version 2.0.3 or newer then flashing new kernel is as easy as typing on keyboard.
Open Terminal Emulator form Settings menu then navigate to directory where you placed unpacked kernel image and finally execute command:
flash_image kernel kernel-091013.imgRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Latest Results
Hello Wasser,
I installed the NEW kernel ... The System Did NOT want to reboot ...
I had to Reboot it three times and I seems To be working ...
I was Able to Disable the Wired EtherNet and Enable and Connect with the Wifi ..
My First Try Hung the Player ... So I rebooted it and The Second Time I was able to connect ...
The Wifi Looks Fine on the Player Display ... I can NOT set the Wifi Player Name using The Included
Software it just Hangs ... It Does NOT seem to Be able to See any Devices ...
This is In software for Wifi that comes with player ...
So I tried the ES File Explorer ...
I was Able to Use ES File Explorer and Mount a Share off My Nas and Tested Part of a Movie it Played ...
I exited ES Explorer and Connect to the Wifi With ADB (From My PC) and it seemed to connect ok but It just Stopped Working after I issues my second or third command ... Very strange ...
So, I check the Player Display and it thinks it is still connected ...
I did a Dmesg and lsmod dump and Have uploaded the results to the below link:
Please let me know if I can Do Any thing Else ...
Michael T.
Originally posted by wasser View PostLast edited by michael2t; 10 October 2013, 12:18.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Hello Wasser
Hello Wasser,
I know this can NOT be easy working on this without the hardware and I wanted to Thank You ... for all of Your help ...
I was also looking at the settings for the Kernel can You change the
Performance Settings to Interactive and ROW This will allow the Player to Boot
Quicker ... As they only get set after the reboot with the performance tool ...
Thanks In Advance ....
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Michael T.
Originally posted by Gormar View PostWait a moment because this kernel for T-R42 (K-R42 with BT) is Work in Progress. You should only consider that option if you flashed any of HFW by Lewy20041.
Thanks for the info. I was too excited for lewy20041's HFW and didn't pay attention. I flashed his HFW into my T-R42 device and now stuck with no ethernet and wifi. I always thought I bought the K-R42 model but didn't realize with Bluetooth it modeled as T-R42 and seems to be different with regard to FW. It looks like a HFW for the T-R42 devices is being worked on and hopefully it is true and can't wait for it. I have been looking all over places for a stock FW for the T-R42 to at least get back running the stock FW while waiting for the HFW but no ones have posted yet.
Thanks.
Thanks.
Originally posted by wasser View Postthe problem is we don't have kernel working on t-r42. I have tried to get kernel working since yesterday, but the process will take time due lacking the hardware, i hope we will have customer-firmware soon for t-r42.
Results
Hello Wasser,
I loaded the new Kernel and it works but it takes a very long time to boot ...
But it does Boot ...
The Wifi is working and I check to see and it seems to be working correctly ... now
I plugged Back In my K-r42 and Tested the Wifi with the Lewy's Firmware 2.0.4 I have loaded.
It does not work with the Wifi Program included either ... Both act the same way nothing
Comes Back ... I believe this program Worked correctly on the stock firmware ...
SO both 2.0.4 wifi and this NEW kernel do NOT work With the Wifi Program ...
When I go to the Settings Page and Look at the Signal Strength for Wifi Under About Status
it says Signal Strength is : 2147483647 dBm 255 asu ... Seems Big to me ???
The Kernel you posted is 1080 p only and the Icons are very small tried setting them back to 720p but it does not work for me ... the 2.0.4 firmware seems to work fine (big icons) for me with the 1080 or 720 p output selectable and work fine...
That really has nothing to do with this ... But I thought It might be why it seems to take sooooo
Long to boot up ...
The Wifi Seems to Be faster than the Wifi on the K-r42 ... strange but good ...
I will download a wifi test program later and see it that is really the case or just something
that seems faster ... as I only see what speed seems to be ...
Once I get the Wifi test results I will Post them ...
Thanks again for all the hard work ..
Here are the outputs
Link to Dmesg and Lsmod :
Michael T.
Originally posted by wasser View Posti will change it later when we get the kernel working on t-r42Last edited by michael2t; 10 October 2013, 15:52.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Wifi Analyzer
Hello Wasser,
I just tested Your Kernel with a Wifi Analyer and it says the Output level is -43 dBm
Not Bad the K-R42 is at -45 dBm ....
-39 dBm when Bluetooth is on ....
I Disabled the Bluetooth while the wifi is on Caused the unit to reboot ...
Michael T.
Originally posted by wasser View Postthe problem is we don't have kernel working on t-r42. I have tried to get kernel working since yesterday, but the process will take time due lacking the hardware, i hope we will have customer-firmware soon for t-r42.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by kadoosh View PostIm using 1.20 final but my flash memory only shows as 2gb instead of the 8gb I should have.
Any work arounds?
v2.0.4
-same as 2.0.3 but with cpu clocked at up to 1.6Ghz insted of 1.8Ghz from 2.0.3
-fixed TV out
Does this mean AV OUT works on this version?Last edited by kadoosh; 10 October 2013, 16:16.
There are currently 5410 users online. 2 members and 5408 guests.
