K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
AW: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by xatang2013 View PostHi Wasser,
Can you upload new firmwares for T-R42 for both 1080p and 720p kernels.
Gesendet von meinem HTC One mit Tapatalk 4
CWM Recovery
Hello Wasser,
Can you post a link to CWM Recovery.img that works with Remote and Lewys 2.0.4 Firmware
Michael T.
Originally posted by wasser View Postt-r42 Firmware uploaded, please take a look in the Forum
Gesendet von meinem HTC One mit Tapatalk 43.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Also in the Kernel could You add the CWM recovery with remote support
Hello Wasser,
For Both 1080p and 720p
Michael T.
Originally posted by michael2t View PostCan you post a link to CWM Recovery.img that works with Remote and Lewys 2.0.4 Firmware
But if you can not find it then there it is explicitely: http://d-h.st/z1KRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
We are talking about the t-r42 software
Hello Gormar,
We are talking about the T-R42 Software ... NOT K-R42
Michael T.
Originally posted by Gormar View PostThere is such a hyperlink in previous post (#975). I even gave you link there: http://www.freaktab.com/showthread.p...ll=1#post97235.
But if you can not find it then there it is explicitely: http://d-h.st/z1K3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by xatang2013 View PostIs it possible if you can upload a 1080p kernel for T-R42 with large icons/density=240 and keymap fix for the stock ir remote?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Gormar---
Hello Gormar,
Thanks For the info ... I am going to get another T-R42 and I want to Use it On TV with 1080p.
Also I would Like to HAVE CWM Recovery in Program so I do NOT have to RELOAD Every thing All over again... And Some of the other CWM commands ....
Thanks For the Info ...
Michael T.
Originally posted by Gormar View PostKernel isn't directly responsible for small or large icons. It is set by system. Change ro.sf.lcd_density value in /system/build.prop to either 240 or 160.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by michael2t View PostWe are talking about the T-R42 Software ... NOT K-R42
Never the less there is minor difference between these two devices (Wifi and LAN chip) which are without consequences to ClockWorkMod because that software doesn't use them.
But if wasser would have time and will to make special CWM recovery for T-R42 then be so.
Once more sorry for butting up.
density will be set automaticly:"Everything is possible if we work together!
Lewy and Wasser
Hello Lewy and Wasser,
Lewy Thanks For the Info I will do it ...
And I want to Let You all know that Wasser Kernal and Lewys 2.0.4 has Been Running for 2 days Now with out any random Reboots ... Which happen 2-3 times every 8 hours on the K-r42 ...
Most Likly that Problem With the Ethernet Errors is causing the Reboots ... as there are NO errors reported with The T-R42 Kernel Wasser Put Together
thanks all for all your hard work ...
Michael T.
Originally posted by lewy20041 View Postor put the kernel to /system/preinstall/ rename it to 1080p.img and just swich resolution in settings.
density will be set automaticly:"3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Thanks for the info.
Have you had a chance to get a stock firmware for the T-R42? I noticed you been waiting for it from Eric from GeekBuying. Are you going to build a HFW for T-R42?
There are currently 3288 users online. 1 members and 3287 guests.
