K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by lewy20041 View Postworking ok.
made a firmware for thouse that need tv out like me.
uploading...
update only for thouse that need tv out support.
wasser can you pm me with 480p kernel?
to: lewy20041 - after intalling only kernel I have very big dpi value, how can I change it in your rom?CS918(old wifi)+Air Mouse ea-01
Out: TV LG HDMI (1 day a week AV out Samsung Tv)
CX919(wifi ap6210)+Mele F10
Out: TV LG HDMI
hi there
i just turn on usb debugging on my new k-42, and then go to my computer to try to install the drivers.
But....the k-42 device don't power on anymore....? something's wrong ?
And by the way, before i enable usb debugging, i try to install the drivers on windows 8, but it keeps saying "drivers are not compatible with your material for x64 blablabla". But my system is x64 and I use the correct one....So....what's wrong ?
well for now, i can do nothing because it does not power on anymore....
anyone has an idea ? charger is dead ????
I'm a little happier. I tried the 2.0.4 version and it has worked (halfway). Remember that the version 2.0.2 i 2.0.3 did not work, I understand that there is more of the announced internal changes between versions 2.0.3 and 2.0.4.
Only two things I have not you run:
- No AC3/DTS passthrough works. (Never has come to work in any version of firmware). My stereo has Dolby Prologic II and AC3 simulates quite well, I'll have to settle.
- Sleep mode wake up 10-15 seconds, I always turn off completely.
Thank you very much lewy20041, Wasser and all for a great job.K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
In: original controler/mini keyboard trackball controler wifi
XBMC Nightly build v13
I can't get any picture with 2.0.x
1.20 works perfect on both tv's in 1080p just reflashed after 2.0.4
Any ideas, its driving me insane.
Thanks for the hard work guys
----- update 20/09/2013----
TV out is blank also. When flashing the firmware after the rkbatchtool is finished (it reports as complete no fail) the blue powerlight on k-r42 goes red. Is this a failure or just a reboot?
Is this a kernel issue or is it just that the res cant be dispalyed on my TV's. Anyone who has had the same problem and fixed please share with me.
Thanks a lot.Last edited by ace-bingz; 20 September 2013, 08:41.DEVICE: K-r42 from geekbuying
OUT: 50 inch lg plasma and 42 inch lg lcd.
IN: droidmote
Originally posted by Hotabych View PostI installed only wasser`s kernel on 2.0.3 with AV out support and its working but not smooth, i tried on LG 1080p plasma (I will try tomorrow on other TV)
I installed wasser's new kernel on 2.0.3 like you did and i have the same issue.AV out is choppy on my tv (like 15 fps), but i remembered not being choppy on my PC's TV card composite input. I will recheck with 2.0.4.
Despite this problem, kernel is more stable than the previous kernel (no reboots).
I also had no dpi changes (dpi=160)Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
Originally posted by curlyboi View Postis recovery mode working? e.g. hold the bottom recovery button and power on with it still pressed
but sometimes when i plug the power adapter to the device and then press "power", the button turn blue 1/4 seconds and then....nothing !
Hi
2.0.4 installed, no new issues, still s/pdif passthru problem on some videos...
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
smartphone remote
Originally posted by djpeterdj View PostHi, thanks for all your support.
Does this ROM still have support for remote control?
Which app do I need to load on my phone?
Thanks again for all your hard work.
just to clarify, my remote control works fine. i am trying to use my phone as a controller
to lewy20041:
pls recheck your build.prop
you made additional space in numbers 16384, is it normal?
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16 384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.evdo_b=4096,87380,256960,4096,1 6384,256960
Out: TV LG HDMI
Originally posted by tinchox5 View PostI couldn't mount samba share on boot (in 1.2.0 rom yes). Did you edit init.d/ or install-recovery.sh? Thank you
P.S I use 2.0.3 firmware. Someone has the same problem?
Originally posted by djpeterdj View Postjust to clarify, my remote control works fine. i am trying to use my phone as a controller_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
cwm-recovery with correct kernel
i uploaded my new cwm-recovery.img with the correct kernel. The new one supports not ony vfat but also ext4/ntfs for external_sd.
Lewy, the cwm-recovery.img, included in 2.0.x, hat wrong kernel! you should please use this one in your next rom.
There are currently 2452 users online. 4 members and 2448 guests.
