K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
thanks all for mirrorsEverything is possible if we work together!
Signature Please guys
Originally posted by algiam View PostWasser kernels I work in version 2.0.1, I burned wasser kernels on 2.0.2 for testing and not working. The strange thing is that it does nothing, it turns on the blue light and soon stops.
algiam and others, please use a signature.
on a thread like this, there are different types of hardware, so it's useful to be able to see what issues people have on different hardware.
tx
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by fredphoesh View Postalgiam and others, please use a signature.
tx
Mark.
I'm the only one not doing the version 2.0.2? The device does not start and 2.0.1 is perfect.
I tried all the previous roms and the only one that does not turn the device is 2.0.2.
K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
In: original controler/mini keyboard trackball controler wifi
XBMC Nightly build v13
Hi, thank you for the update!
I tested 2.0.2. Very nice!! The new "change resolution" option is working very well and i was able to switch to 720p kernel
No HDMI issues
All apk i tested worked without problem.
Seems stable so far.
Edit: There is video stuttering problem when bar and mouse is hidden.
Great work!
I just have one question.
Wasser said that the last kernels he posted are Overclocked kernels. What is the difference between the 2.0.2 and the previous released kernels? I know that CPU scalability is limited from 1.2 to 1.8 on this kernel. But what about ddr and gpu frequency? Do i have to put a heatsing to prevent instability? I notice the box runs a bit hotter than before. Not much, but noticeable.Last edited by psychorat; 16 September 2013, 20:54.Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
with implemented swich resolution its just downscale apps launcher etc to 720p.
in next firmware real resolution sweech for 1080p and 720p kernel and also cwm.
all already working for me;pEverything is possible if we work together!
update in couple days so dont setup to much your devicesEverything is possible if we work together!
Cant help myself...
uploading 2.0.3
Changelog:
v2.0.3
-cwm recovery (backup-restore your firmware)
-Xbox360 wirless gamepad butons remaped to support more games
-swich between 1080p kernel and 720p kernel (default res real 720p, for real 1080p go to Settings>Advanced>Switch Resolution) with simple press of a button from your tv
as of 2.0.3 cwm ver will be avilible toEverything is possible if we work together!
Where can i see the ddr frequency from this rom?
I have the EXOON POWER PRO and under specifications they wrote:
MemoryHynix DDR3 2GB, Frequence:1333MHz
So can i set the ddr frequency manually or is it set to 1333MHz by you rom?
Gesendet von meinem iPad mit Tapatalk HDDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
ddr frequency is set by kernel.
i dont know what frequency wasser used.
i used last wasser kernels posted here.Everything is possible if we work together!
Originally posted by DrHansAPlast View PostHi,
just installed 2.02, everythinng works, but no luck with DTS on my CS918,
AC3 passthrough works with all players, also in patched XBMC.
GerdEverything is possible if we work together!
Watch out DDR.
Originally posted by walter77 View PostSo can i set the ddr frequency manually or is it set to 1333MHz
I think the highest safe overclock is 720MHz which will give 1440MHz DDR.
There should be some wasser kernel with that setting. I do not know any tool which will allow memory frequency change on the fly.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Observations on 2.02 for K-R42
I loaded 2.02 Beta on my K-R42 yesterday. Thanks for the hard work on the ROM lewy20041 and wasser, I'm delighted that DTS passthrough on SPDIF now works. Fantastic to get 5.1 surround sound at last!
Some additional observations:
Playing 1080P file, video seems to drop a frame at a regular interval, not exactly stuttering and watchable still, but definitely noticeable. Using 1080P 24Hz HDMI setting (as I'm writing this, I'm wondering if using the 60Hz might help with this, I'll try later). Same video plays smoothly on the PS3.
Doesn't seem as stable as 1.2.2. It froze requiring pulling the power cord on setting Google username and password during setup and also a few times in Netflix (using 16x bitrate version).
Google Play Movies loads but never plays movie. This seems odd as in the pre-release of 2.02 (not the official 2.02 on the first page of the forum) Google Play Movies was slow but did eventually play the movie. Might be something to do with wifi trouble though, see below.
This is the first ROM I have had wifi trouble. Getting very low speed connections to my router it will not use WPA2 or AES encryption and hence is not using wireless n speeds.
Getting static noise in XBMC on optical audio setting using the special version with pass through. Note, as mentioned, pass through works fine in MX Player and native player.
Cannot get XBMC to recognise video files on a USB stick. It doesn't seem to have any option to select this location, despite MX player and native player picking those files up without any problems. I'm new to XBMC so I might not be looking in the right place.
There are currently 1895 users online. 1 members and 1894 guests.
