K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by wasser View Post
with this kernel i get a picture on boot and everything is ok on my hd tv - but if i change the screen resolution within settings to 1080 50/60 - i do not get a picture.
with this kernel my lan interface is not getting ip.
used on ut1 with fw 2.0.1
thanks
holli
Originally posted by algiam View PostYes, the rom is stable.
Bravo !
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by prism View Post@wasser none of the keys is working... I have attached image of remote controller for your info.Thanks for looking into it..
Originally posted by wasser View Posti don't think so. i made 1080P-60HZ as default in the kernel, which causes this problem
I hope for a fix when you'll have the time. Apart this problem, your kernels make this box really fast!
ThanksDevice : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
Originally posted by psychorat View PostOk then.. i thought you made 720p as default in the test kernel u posted earlier.
i even uploaded new 1080p kernel with some reverts to fix the HDMI issues
Please test!
thanks
I've done some basic testing on all 4 kernels uploaded today, the three 1080's and the 720.
Antutu test causes a sudden power off crash with all of these kernels, (I have not tried Antutu on this device before) Also, with each kernel, I get "XBMC not responding" after booting up... which is odd since xbmc is not being started.IMO the tiny fonts and general interface is way too small with the 1080 kernels - IMO it should be big enough for a 50 year old man to read on a 42inch screen 2.5meters away!
specifically:
kernel_marvin_k-r42_gpu600o_vsfsam_cpu1800_1080p_ddr600
Antutu test caused sudden power off when doing a cpu float performance part of the test
hd video stops many times with 1080p h.264 video
kernel_marvin_k-r42_gpu600o_vsfsam_cpu1800_1080p_ddr720
xbmc video playback is smooth with 1080p h.264 video
kernel_marvin_k-r42_gpu798_vsfsam_cpu1920_1080p_ddr720
black screen, could not test
kernel 720p (13-09-2013)
preferred incon/font size on home screen/apps/system
xbmc hd playback not great, stops and buffers again and again
Antutu test caused power off crash after about 1% into the test
keep up the energetic work guys, its inspiring!
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
specifically:
Mark.
Sleep Mode
The rom is stable and has not crashed even once but from what I see, everyone gets something different happens. These PC-box should have different components according to time of manufacture.
There are people who operate AC3 and DTS, only AC3 others. In my device none.
When I activate the sleep mode after 10-15 seconds the device wakes up alone, I disconnected the network cable and the same. Anyone else will happen? It is very annoying to switch the power off and on each time for use.
Thank you,K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
In: original controler/mini keyboard trackball controler wifi
XBMC Nightly build v13
Originally posted by wasser View Postthe latest 720p-kernel which i uploaded today has 720p as default.
Please test!
thanks
The latest 720p test kernel has the problem even with the default resolution set to 720p.Device : CS918 --> Sony Bravia 32" 720p
Please test!
thanks
this kernel is working on my hd tv now in all modes as well (ut1) i use now 1080/60 cool thanks.
but no dts/dolby on tvhaedend hd channels only shutter noise on spdif through xbmc - if i use analoge the sound is ok
i figured out why the lan cable is not working - because of the changing mac and i only have few dhcp addresses available because all my devices use static ip except my phone's and tablets.
thanks
holli
Please test!
thanks
No more Lines allover the tv. You did it and keep a note of what was changed. ill be keeping this box on this kernel and test your new stuff on another .
thanks
holli
I know it dont work.
Test passtrougt with stock player.
For xbmc passtrought you need special xbmc.apk and patched libmedia.so (I will add it in next realise)Everything is possible if we work together!
Originally posted by algiam View PostWhen I activate the sleep mode after 10-15 seconds the device wakes up alone, I disconnected the network cable and the same. Anyone else will happen?
Ben
Please test!
thanks
Great job wasser !!!
This kernel have 1080p/24 /50 /60 that works on my Bravia TV (/25 /30 are not supported by TV this is normal).
Franckfor windows8.1 drivers fix follow this.
There are currently 2531 users online. 9 members and 2522 guests.
