K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
I installed version 1.2.0 1080p final and I was a little disappointed. This version is not much different from the original firmware of cs918. Including the behavior of the shutdown button is the same. I click shutdown and it just sits in standby, move the mouse, it turns on again =( Is that right?
Version 2.0.2 is great, shutdown really works, but does not have tv out and the remote control that came with the cs918 does not work =(
And I'd like to tell me how I open storage on the PC to include external apk files and install them.
Originally posted by lewy20041 View Postfirst post updated with 2.0.3
please test
Indeed thank you so much for your wonderful work. Great Rom working so well with CS918. I really love the true 1080p res. Except for the IR remote controller every other features are simply awesome. It will be perfect if you could fix the IR remote controller issue in your next release. Really love all you guys for making this box so enjoyable! Keep up the good work.. we appreciate very much!!
Testing 2.0.3 ...
Very strange but in your recovery my two airmouse not working, but in recovery from http://www.FreakTab.com/showthread.php?t=6805 all ok.
Отправленно от моего Nexus 7 с помощью Tapatalk 4CS918(old wifi)+Air Mouse ea-01
Out: TV LG HDMI (1 day a week AV out Samsung Tv)
CX919(wifi ap6210)+Mele F10
Out: TV LG HDMI
Originally posted by lewy20041 View Postdts should work with spdif, not yet with hdmi:"
no luck with DTS, i connect the CS918 with optical kabel, switched the receiver to optical input
and tried every possible sound settings followed by a reboot. No DTS with every player, only noise and most of the times players crashed or system reboots while playing DTS files.
Switched back to HDMI sound settings and everything works, only DTS sound = stereo.
Not a real big problem, i have only 10 Videos with DTS...
GerdCS918 with v1.1.1 justXbmc firmware from lewy20041
Out: HDMI
In: Logitech K400R keyboard, Flirc adapter for XBMC and Logitech Harmony
remote control
Originally posted by prism View PostExcept for the IR remote controller every other features are simply awesome. It will be perfect if you could fix the IR remote controller issue in your next release.. If you have got remote version with only multimedia keys then you have no luck
My version is quite easy to configure as I like by editing corresponding file: /system/user/keylayout/rkxx-remote.kl. I somehow manage to get all keys working but I cannot force Android to execute function exactly like it is written on these keys. Especially MEDIA (RED) and TV (GREEN) because there is no adequate key code for these functions. In original firmware there was probably some application to menage that.
I'm currently flashing newest firmware version (2.0.3) to my box and when I finish successfully I will write which lines to change and what key codes and scan codes to use.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Thanks so much for your kind assistance. By the way I have provided the link to my CS918 stock rom and 2 pages back you could also find the mirror to it. In this rom the IR remote controller works perfectly well. I am not sure if you could made reference to this Rom in determining the key and scan codes being used. Well just hope that this rom could be of help to you too. Meanwhile look forward to your instruction and advise.
Gerd
+ can work very well with some videos
+ can produce lag: video stops, receiver switch from dts to lpcm, then return to dts then the video restarts for a few seconds and stop again and again.
+ can output raw format but seen as lpcm by the receiver and then produce awful noises.
Thoses videos with passthru issues plays fine in downmix mode (but only 2.0 dpl).
This passthru issu can be reproduce on stock player and mx player.
I should test with fw 2.0.2 because I dont remenber of such problem with this firmware...
--> edit -- flashed and tested, same issue fw 2.0.2
Hope this helps
Franck.Last edited by franckleroy; 17 September 2013, 17:36.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by prism View PostBy the way I have provided the link to my CS918 stock rom and 2 pages back you could also find the mirror to it. In this rom the IR remote controller works perfectly well. I am not sure if you could made reference to this Rom in determining the key and scan codes being used. Well just hope that this rom could be of help to you too. Meanwhile look forward to your instruction and advise.
But not all hope is lost. IF driver for RK remote builded into "wasser's" kernel is compatible with your remote control then you may only need modyfied configuration which mean associate Scan Codes with appropriate Android Key Codes to do "something" usefull. It might be imposible to find working solution from Internet (stray rkxx_remote.kl file) because after last changes to RK remote driver in "wasser's" kernel Scan Codes are different. Without actual identical remote control no one can supply proper configuration file for you.
First. You must install application which will show you input Scan Codes and eventualy associated Key Codes. The best I know is "Key Test" but it isn't available on Google Play Store. I will try to share my copy of this app.
Then if you are lucky and can read any Scan Codes from key presses on you remote control it will be possible to alter configuration file.
Original firmware isn't helpful because there is different kernel and probably config files. It may seems that lewy20041's hybrid firmware is a work of the Frankenstein but in reality it isn't. Besides dissecting compiled kernel to extract code that support version of remote control which you have is beyond capability of almost anyone if even possible.
Last edited by Gormar; 17 September 2013, 21:04.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostI'm affraid that you misunderstood me. I can only contribute by proposing changes in HFW firmware when I have exact same hardware in this case remote control. But I don't. Yours is almost exact opposite to my version which doesn't have any multimedia buttons besides "change track".
And I would like to know how I open storage on the PC to include external apk files and install them, like happens in smartphones? When I connect cs918 in my pc nothing happens, the window does not open storage, how to do?
Originally posted by rlcdo View PostI would also like that remote control and tv out works in these firmwares.
As of lack the mass storage capability it is probably temporary disabled in the newest HFW version. But in Google Play store are some application which offer that function.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostI suppose that you own similar remote controler as prism? It might be not possible to get it working in these modyfied firmwares as it is now. If there are no Scan Codes generated by RK remote driver build into the kernel then it is simply impossible to do anything about this problem.
And about the mass storage, could you name a few applications that allow me that?
Outstanding ROM my compliments to everyone involved making it to what it is now!
Love the 720-1080p switch and it runs very fast.
I have seen no video stutters so far, dts seems to be working ok on passthrough but only started testing just yet.
Keep up the good work you guys are awesome!K-R42 box with v2.0.3 of lewy20041 rom
Out: HDMI
In: Rii i8 Mini 2.4G Wireless Keyboard
There are currently 2343 users online. 0 members and 2343 guests.
