K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by pablo11 View PostI have the latest (Late August) factory firmware for the Kaiboer F4 - Ugoos UT1 if anyone is interested. Specifically lewy. It was released internally at the company a few weeks ago......
Originally posted by backlit View PostOf course I edit file in init.d folder for my configuration. Bad yesterday - unfortunately didn’t mount. I dont’t change configuration so it is very strange.
I tried several times to mount samba shares on boot with 2.0.3 firmware, but I couldn´t. So, meanwhile I'm mounting the resourses using a terminal and typing "busybox mount-t cifs //myip/folder /mnt/Samba_1 -o username=guest,password=".
I tried several times to mount samba shares on boot with 2.0.3 firmware, but I couldn´t. So, meanwhile I'm mounting the resourses using a terminal and typing "busybox mount -t cifs //myip/folder /mnt/Samba_1 -o username=guest,password=".
Hello Wasser...Question
Hello Wasser,
I downloaded the Kernal and flashed it with Finless tool ...
And NOW I get a Menu with the CWM-recovery boot list ...
I have Never Used this before ...
Can You tell me how to Use this ... thank You
I wanted to Test My USB NTFS Hard drive with Your New Kernel ..
Michael T.
Originally posted by wasser View Posti uploaded my new cwm-recovery.img with the correct kernel. The new one supports not ony vfat but also ext4/ntfs for external_sd.
Lewy, the cwm-recovery.img, included in 2.0.x, hat wrong kernel! you should please use this one in your next rom.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
@michael2t.
cwm-recovery.img contains not only kernel. It is recovery partition with ClockWorkMod software. To find out how to use it search with Google. You must flash it into appropriate partition called "recovery" not where working kernel is.
Now you must flash proper kernel again.
As for NTFS USB drive it should work in R/W mode with almost any kernel compiled by wasser for K-R42 because there is Fuse agent build into them.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hello Gormar
Hello Gormar,
Thanks For the Help ...
I will Reflash ...
Michael T.
As for NTFS USB drive it should work in R/W mode with almost any kernel compiled by wasser for K-R42 because there is Fuse agent build into them.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Mac Address
Hello Gormar,
Thanks for the nice post about the mac address ...
Is there a way to Find out what the Real Mac address of my player is ???
Thanks In advance
Michael T.Last edited by michael2t; 20 September 2013, 17:03.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Originally posted by michael2t View PostIs there a way to Find out what the Real Mac address of my player ???.
Short term solution would be to copy WLAN MAC.
But check first if it isn't randomly generated or rather I suppose it is read from not properly initiated memory like LAN MAC (at 0x10204000) RK29xx style. In RK30xx chips it should be read from GPIO pins and not SRAM.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
I will put it into next update.Everything is possible if we work together!
It will help alot.Everything is possible if we work together!
There are currently 1465 users online. 0 members and 1465 guests.
