K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
your latest kernels output 1080p res at boot and the older ones 720p so this may be the problem for some tvs:"
thanks for oveclocked kernelsEverything is possible if we work together!
Originally posted by lewy20041 View Postto get passtrougt
go to setting>sound change the output.
do not install any drivers for mx player, passtrought will only work in h/w mode.
try with stock player and gallery app.
and post back.
MX Player without any special drivers can now play about 80% of my video files with AC3,
also the standard android player. MX have sometimes problems to switch to ac3, but if i restart the
video most of the times it works.
But no luck with DTS, MX and standard players plays only stereo or noise...
I set the soundmanager to RK29_RK1000Passthrough
Regards from Germany
GerdCS918 with v1.1.1 justXbmc firmware from lewy20041
Out: HDMI
In: Logitech K400R keyboard, Flirc adapter for XBMC and Logitech Harmony
Originally posted by lewy20041 View Postyour latest kernels output 1080p res at boot and the older ones 720p so this may be the problem for some tvs:"thanks for oveclocked kernels
Originally posted by wasser View Postwhich kernel exactly does not have this issue? it could be a regression in latest kernelDevice : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
Originally posted by psychorat View PostI checked 2 other kernels that you posted before, 9-9-13 720p and the 28-8-13 720p. All have this issue.
But if I flash last kernel (09/10 I think) it adds 1080p/24 /25 /30 to the old ones; /50 /60
and only 1080p/24 is OK, other procude black screen or a error message on the TV about invalid resolution.
The problem is not only on HDMI TVs but also on some PC LCD.
I try also on a DVI TV, but even with the stock fw, the display is totaly scrambled...
Hope this helps
Franck.
--edit --
kernel-1080p-100913.img -> only 1080p/24 works on my fullHD Sony Bravia TV 40"
I'll test tonite all kernel / all resolution and publish the matrix.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by wasser View Post1) i cannot reproduce the random shutdown in k-r42, it could be that the hardware is not 100% identical
2) it doesn't work correct because the ir remote is not the same from r-k42, it could be that the driver is not included in my kernel. Does any key from your ir remote work?
wasser
Thanks for looking into it..
Thanks man !!
Franck.for windows8.1 drivers fix follow this.
I tested but unfortunately the issue is still there
Only 480p and 576p modes work for me (like in previous kernel). All other modes give black screens and some horizontal noise lines here and there when the screen shows something.The resolution is still 1080p by default.Device : CS918 --> Sony Bravia 32" 720p
May be the choice of default resolution is in the fw and not in kernel ?
i tried all 3 kernels on my ut1 - but i can not get lan networking with it working.
with the prev. the lan was working.
best regards
holli
Originally posted by prism View PostWow! its really awesome. Most features seems to be working fast and fine on CS918 except for the followings issues:
1. frequent random auto shut down for no reasons (need to power up the set again).
2. Remote controller that comes with the set not working still.
Appreciated and you really make my day ... best rom for CS918 so far. Look forward to your next release of 1080p soon.
I also have a cs918 and do not have any of the random power offs that I used to have in 1.2.2... so I would flash again. Are you also using 2.0.1 with 720p?
my remote controller is also not working at all.
cheers
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Keyboard Mouse
Hello Lewy,
I saw this on Your Facebook page ... Does it work Well With The k42/t-42 Player and your Latest
2.0.1 Firmware ???
Look Nice ... Does it Work Good too ??
Rii mini i25
What Kind of Range do You get ... ??
Trying to Get a Mouse/keyboard You will be supporting ... (((SMILES)))
Thanks Lewy
Michael T.
thanks for oveclocked kernels3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
There are currently 1640 users online. 1 members and 1639 guests.
