i have attached pic
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
DS3 Controllor + Mouse
Hello everyone,
I was wondering, anyone get lucky connecting dualshock 3 to the device and play games with it? also I can get the mouse to work either,tin core map is a mess, at list for me and I can't install some apps like tv launcher or rk remote.
Any ideas?
I am using stable version.
Originally posted by eli200601 View Postso i did and i get error (code 10),
i have attached pic
[ATTACH=CONFIG]3280[/ATTACH]
Its not that you have a bad cable. Just do not use any adapters or extension combo cables. Buy a MicroUSB to USB (male) cable if you dont have one and it will work.
I had the same problem like many others. Please read the first pages in this thread about it.Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
New fw works fine. but i freezed in the middle of installing something.
Anyway.
For the second run started video.
DTS works. 5.1 works.
.264 and normal sized videos runs perfectly.
full hd video sized to 0x0 and no picture.
for tomorrow I'll watch some videos from begining to the ends.
first reaction is a big "GOAL".
as replied in email
thanks for feedback.
its good that dts is working i dont have such reciver so couldn test it myself.
as of full hd video be sure to tray with galery and mx player.
just google apkfreak you will find my facebooke pageEverything is possible if we work together!
freakktab freaks me out!
i find it meanwhile freaktab goes online again.
i tried the videos on plex.
since this firmware (kingnovel offical, and yours before it) full hd vids are started well.
just with this fw got this 0x0 dim and blank screen error.
but the sound goes under this blank screen, so the video starts, just got some error to project it to the screen.
how can i activate the IR remote?
should i use an app for it? or what can i set to work with it?
i done everything with an Wless mouse (with usb receiver).
Hello,
I just installed this new firmware and so far what I have seen is:
- No DHCP works, static IP set up and works well.
- If I turn off from the remote and I can not restart, I have to disconnect the power and reconnect.
- Pass-trought does not work, just hear constant noise, like the stock.
I see the options in the audio menu selecione pass-trought but I did not do anything.
I have a K-R42.
Thanks for everything and for your time.K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
In: original controler/mini keyboard trackball controler wifi
XBMC Nightly build v13
Originally posted by Kalk View PostNew fw works fine. but i freezed in the middle of installing something.
Anyway.
Some trick to run the AC3? I have not been able to make it work. Use XMBC 13, which app did you use to test this?
Thank you,K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
i have attached pic
I had similar problem when i used USB port integrated into my monitor (e.g monitor has USB HUB).I moved to a port on MB and now everything is working perfectly.
Hello,
I have a K-R42.
some users are saying that it work and some saying its not working.
dolby passtrougt working for sure as i can test it myself
and as of now 1 user said dts is working and 1 said is not.
hym.
power off from remote will shutoff device if you want to get it to sleep pres sleep buton so it will wake up using remote.
after power off (complite shoutdown) there is no need to unplug the power from device just press power button on it.
dhcp is working for me and never had a problem with it:"
what device do you have?Everything is possible if we work together!
Originally posted by algiam View PostSome trick to run the AC3? I have not been able to make it work. Use XMBC 13, which app did you use to test this?
Thank you,
i'm not tested it in XBMC yet.
tomorrow i'll try to sratch here a more experienced feedback. i'll try the xbmc for you in it.
anyway on my dekstop the xbmc has settings for several sound output in SYSTEM/SETTINGS/SYSTEM/AUDIO OUTPUT.
while i'll test it, try in there, maybe U can got the answere there.
Thank you,
only native player and mx.Everything is possible if we work together!
hym.
I will continue testing and combinations to see if I see something weird.
What most concerns me is the AC3 the rest I do not care.
I've been following this thread long, long before they have this device, just 2 days.
Thanks for everything.K-r42 box with 2.0.4 Lewy20041
Out: TV LG HDMI
Hi Lewy. Thank you for the update! I downloaded and tested v2.0.1 but i have a couple of problems with my C918
AV out - I get thick yellow stripes after the first logo (the one with the Geekbuying logo). The desktop is running in the background but the stripes makes it unusable.
Hdmi - The initial resolution is set to 1080p but the signal is not stable. It shows for 2-3 seconds and then is looses the signal for a while and then it shows again for 2-3 seconds and so on. I changed the resolution to 720p 60hz in settings but same story.
I rebooted 2-3 times but nothing changes.
My TV is Sony bravia 32" (720p native) wich plays nice with your FW v1.12.Device : CS918 --> Sony Bravia 32" 720p
There are currently 1486 users online. 0 members and 1486 guests.
