K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by yoyopfk View PostHello to all,
Is there any chance to make this rom working on T-R42/CS918 with Bluetooth,please?
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by geklas View Posth...and i have the same problem...random resets..i use 2.0.4 version on K-R42
RK3288 Devices
I just got one of these boxes. First thing i did was download this rom and flash. End result no output from HDMI or Composite. I have flashed twice and the same result. The latest version has some kind of issue, my Samsung tv sees something on the hdmi port but cannot detect a signal.
I´ll try another rom for the time being
HELP: Flashed with firmware and now won't boot
I tried flashing my unit with wasser using the program where there are multiple checkmarks and files. It said successful but when I tried to boot my device it would show the splash screen for a couple minutes and then the screen would go black and the device would shut off (blue power light off). I tried flashing back to lewy20041 firmware using the program where you just select one image file. It said successful and when I boot the device up now it had lewy's splash screen on it but it does the same...splash screen for a minute, and then device does a full power off. Its like its missing a file or something. I don't think its the device as it was fine before. I am kind of a neewbie with this. Do I need to r-flash it with a certain file and/or program to fix? i appreciate anyones help. The device is a paper weight now unless I can fix somehow.
TN-BX09_V2.1
Originally posted by lefizz View PostJust to say my unit appears to be a 2.1 rev if that helps. I also tried justxbmc which boots fine although I think I would prefer a more full featured ROM.
P.S. I checked again your picture and noticed that you have different NAND Flash and memory modules. But from such low quality picture I cannot decipher if it can have any impact on kernel configuration (vide RAM speed).RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
TN-BX09_V2.1 with TOSHIBA NAND FLASH and NANYA DDR3 RAM modules.
Originally posted by lefizz View PostThis one is a bit better
Could you make some close ups of these chips. For the best resoult use macro function of your camera.Last edited by Gormar; 19 November 2013, 09:34.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by alexandroff View PostHi lewy,I installed the Beta v2.0.3 firmware to my device.However, th Skype seems not working proprely.Once I call someone it is going to restart the Skype and that is all.Any advice to resolve the issue.Otherwise the Beta v2.0.3 rocks!
CS918 new rom from China
This version is much better then I tried before on CS918 NObt, everything works fine, including power on/off, resolution and smooth UI.
PS:first time reboot if nothing output from HDMI, you should use composite video and goto setup to change screen scale(max. or min.) and reboot.
There are currently 2561 users online. 2 members and 2559 guests.
