Hi, I have been testing 3.2F with my Jesurun DX05.
Overall performance is very good (using 720p since my projector doesn't go higher than that).
Only problems I have noticed:
- Random shutdowns (I have just USB BT keyboard which worked with previous versions as well as the wasser firmware), the device just turns itself off. Very frustrating - can I see some log for that? Sometimes, the problem is the exact opposite - I select power off, and it reboots instead. I wake up in the morning only to see the box running (I obviously don't wait for it to complete shutdown to be sure, that would be annoying...)
- WiFi Display not working. Never tried that one before, so not sure if it worked on any other version but does anyone know how to actually get this working? I have a Intel WiDi installed on my laptop and when scanning, it just doesn't see any devices. I would like to broadcast 3D gameplay from the laptop to Jesurun for the audience to watch. Temporary solution is Splashtop app, which is pretty smooth but the game has to run in Windowed mode, which is inconvenient as hell.
