HPH NT-V8 RK3368 Marshmallow ROM by mo123
Originally posted by BEN001 View PostRK3368 V99 Hero , android 7.1.2 https://yadi.sk/d/94iqBQ99TzHkqw
It's not possible to modify Nougat, so I can't fix any of the hundreds of bugs in that firmware.
I don't have RK3368 anymore, moved on to RK3328.
If I have time, will try to update my firmware but won't know if it will boot as I can't test it.
Yes I saw it, maybe will help the few users still using RK3368 but without a Nougat bootloader I don't know.
link to the firmware mod- bootloader in the firmware changed for the kernel 4.4
reference source
http://4pda.ru/forum/index.php?showt...ost&p=79271855Last edited by BEN001; 21 November 2018, 22:37.
Originally posted by BEN001 View Postlink to the firmware mod- bootloader in the firmware changed for the kernel 4.4
reference source
so you mean it boots on your NT-V8 , sounds good , please report if there are many Bugs
& how it runs , what about "root" , maybe i can try this on my UT4 , would be nice ,
greetings / gefattern
Hi mo123, Could you tell me how much of a work it would be to get Zidoo X6 Pro working better with this (or maybe with your lollipop version) ROM? Most likely I would like to get second USB port to work and possibly the remote. Your ROMs are the only ones that allow DRM protected streaming with the applications I use, so cOOLio ROM is not suitable to me. He has instructions to improve Zidoo support with his ROM, so I was wondering if anything like this can be used with your ROMs. Flashing different kernel or resources or something to get better functionality. Is there anything that could work?
Originally posted by Obnoxio View PostHi mo123, Could you tell me how much of a work it would be to get Zidoo X6 Pro working better with this (or maybe with your lollipop version) ROM? Most likely I would like to get second USB port to work and possibly the remote. Your ROMs are the only ones that allow DRM protected streaming with the applications I use, so cOOLio ROM is not suitable to me. He has instructions to improve Zidoo support with his ROM, so I was wondering if anything like this can be used with your ROMs. Flashing different kernel or resources or something to get better functionality. Is there anything that could work?
Since there is no open-source drivers for the Zidoo X6 remote or any MM or Nougat firmware, it would not be possible to add support for the remote.
Originally posted by BEN001 View Posttest Android 8.1.0 Geekbench 4.3.1 for Android AArch64
http://browser.geekbench.com/v4/cpu/11053630
this means 8.1 comes closer to RK3368 , or what ??? hopefully ,
would be nice to use 8.1 on my UT4 ,
Hi ,
I flashed with FactoryTool v1.63, Restore here
That ROM has a very unstable launcher and lots of bugs I find.
I'm making a custom ROM to improve things.
Can you test if https://yadi.sk/d/94iqBQ99TzHkqw works on UT4?
loaded it , think i gone try it this Weekend , hope that all comes good ,
but will RK ever release 8.1 for RK3368 or RK3288 ??? , because my
UT3 is still in same state , SDBoot with UM3 Rom , runs well with SD ,
but the Storage is not full usable , i really want to use both further , i
want to build a PCB double Decker , same size , but this stands on a
different Paper ,
Hi Mo123 ,
different Paper ,
Rockchip already released 8.1 for RK3288, eg. some Firefly RK3288 device already has Android 8.1 firmware to download.
But it didn't boot on my device.
Lots of manufacturers only want to sell new devices now, so will be difficult to update older ones.
They already work on Android Pie for RK3328 now with Amazon Prime Video support, so should be available in a month or two, can't wait.
I heard RK will release another new box in 2019 with Dolby Vision, AV1, HDR10+ and better GPU.
You will then also need a new tv again to play all these new formats, then a year later 8K comes out again(already in Japan) and another new tv box, avr equipment and tv is needed.
You just can't keep up with all the new technology anymore.
Originally posted by mo123 View PostCan you test if https://yadi.sk/d/94iqBQ99TzHkqw works on UT4?
Hi Mo123 ,
good News , it runs , but no Wifi , Bluetooth seems to work , the System runs smooth , but of course ,
as always , bad translated atv.Settings.apk implemented in this Rom too , tonight i test some of my
1080p .mp4 files , but think all will run good , is it possible to get Wifi working ???
info , flashed it with FactoryTool 1.63 ( but log says still Version 1.5) , they used Kernel 4.4.83 , the
Box shows correct 2GB Ram & 16GB Rom , Info Modell : TG-TB-07 ,
There are currently 1783 users online. 1 members and 1782 guests.
