HPH NT-V8 RK3368 Marshmallow ROM by mo123
    I hope it will be possible in future and Rockchip still supports RK3368 and not just focus on their newer chipsets.
    I know the RK3288 will get Nougat support soon that was released before the RK3368 chipset and it's upgrade version RK3399(with built-in hard-drive bay) will launch with Nougat next month.
    I'm currently working on custom Nougat firmware for RK3328 NT-N9, the upgrade version of RK3368 NT-V8 with full Kodi 18 support and it works great.
    Double WOW!!!
    kind regards
    cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
    http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
      Hi
      Can you try Kodi 18 here?
      They fixed some Dolby Digital bug on Denon reveivers and it should work for other receivers too in above Kodi.
      [Android] Map SL/SR channels to BL/BR for audiotrack Description 5.1 streams with Channel Layout: FL, FR, FC, LFE, SL, SR PCM do not play dolby on some AVR (e.g. denon). Instead they fall back to s...
      Maybe you have the same problem of videos quiting?
      Latest Kodi 18 can solve the samba problem of videos quiting.
      If you play the same videos with MXPlayer or 'Video' player, is the Dolby Digital audio correct then and it is only a problem in Kodi/FTMC?
      I'm surprised by Kodi 18, it works very well even deinterlacing works automatically.
      I think it can be used instead of other Kodi's in my ROM since RKMC/FTMC is not needed on RK3368 as it doesn't support advanced features like 10-bit, HDR or VP9 anyway.
      mo123 Kodi 17 and 18 reboots my Ugoos UT4 all the time , only your version, RKMC 16.1 works fine for me.
        I am using native Kodi 18 from the kodi website and have very little problems...
        kind regards
          So am I, are you playing from a HDD or streaming via a pc network? as soon as my stuff starts scraping is when it bombs out my media center, do u have a UT4?
            Nope, a "HPH NT-V8" - Most excellent and underrated machine!
            kind regards
              I'm trying to flash this ROM (v1.5) for the first time on my Zidoo X6 Pro running stock 1.45 firmware provided by Zidoo. However, the box is not getting recognized by my PC when I connect the OTG port on the Android box to the PC.
              I have checked (enabled) the following
              • Developer Options -> Enable USB debugging
              • Settings -> USB -> Connect to PC
              and followed the instructions (connect the OTG cable, keep the reset button pressed and connect power to the Zidoo X6 Pro). Yet, the device is not getting recognized. I have checked the cable and the USB port separately, to work fine.
              What am I doing wrong? Can someone please help? I'd very much love to install this ROM.
              Thanks.
                Originally posted by hoodafukisalice View Post
                Thanks.
                Did you install the drivers?
                Then follow this guide
                UltraByRich Consulting Group is a premier marketing consultancy specializing in business marketing services. We help brands grow with expert strategies in digital advertising, branding, SEO, and conversion optimization. Drive results and scale your business with data-driven marketing solutions tailored to your needs.
                  http://rricketts.com/how-to-properly...-windows-7810/
                  Firstly, thank you for replying immediately with help, I tried a number of steps on both Windows and Linux, but of no avail.
                  1. Yes, I did install the drivers (on Windows 10 Pro). However, the device is not getting recognized. I opened up Device Manager to check for names with Unknown/Rock device, but none was displayed.
                  2. I tried setting these as well: SUPPORTLOWUSB=TRUE and FULLSPEEDUSB=TRUE, in the config.ini file for the Rockchip tool, but still didn't get recognized
                  3. Then I tried DriverAssistant and FactoryTool from your tip. That didn't work either.
                  4. To verify it's not an issue with Windows, I connected the device to a Linux machine and tried with Rockchip Linux Upgrade Tool as well (git clone https://github.com/geekboxzone/lollipop_RKTools.git). Instructions from http://www.hotmcu.com/wiki/Flashing_..._Rockchip_Tool. That does not recognize either.
                  5. I did verify that the RK3368 box does go into Recovery mode with both Windows and Linux when keeping the reset pin pressed, connecting to PC, followed by connecting power
                  6. Since none of the above worked for me, I tried one last step of creating a upgrade disk (sd card). Instructions from http://chinagadgetsreviews.com/downl...tool-v1-4.html. On booting with this, the display is just blank. I patiently waited for 20 minutes before removing power to ensure I don't brick the device while the flash might be getting updated. Rebooted to see the firmware was booting stock! So nothing had happened. I tried this process twice, but with the same result.
                  I'm clueless now. Would it possible to make an update.zip file that we can flash from recovery? There is some updater script and other files that details what goes into which partition etc., but I'm not good with the internals. If you can guide me, I can try to make one (hopefully I don't brick it though)!
                    Update: I used another cable and flashed the ROM successfully. God knows why the earlier cable I used worked while transferring data and charging and wouldn't work for the PC detecting the Android box, but I bought a new cable and got around the problem.
                    Observation: This ROM is just superfast! Especially coming from Zidoo's Lollipop stock, one can perceive the difference; apps load in a snap. There are a few crashes here and there, but are minor.
                    Many thanks mo123 for being patient with users and continuing to update your ROM. Cheers.
                      Hi mo123 Any news on the Android 7 release?
                      kind regards
                        I'll try to find out.
                        But I think only new RK3328, RK3399(both already run Nougat) &, RK3229, RK3288 will get Nougat.
                          already exists Teclast P10 – Tablet with Android 7.0 Nougat
                          Rockchip RK3368 1.34GHz Octa Core
                          GPU: PowerVR SGX6110
                          link:
                            Hi ,
                            once more , please let us discuss your "boot" Problem here , better .
                            I think it has todo with the extra "ShutdownMenu.apk" that Mo123 made for this Rom ,
                            you can try to use the Stock one , like i do , but for this you have to delete the other one .
                            greetings / gefattern
                              Hi ,
                              'Scraping' - getting video file information and posters to show in an app like Kodi/other media player app.
                              I think there are some files renamed incorrectly, maybe file names are too long or contain strange characters that Kodi can't read or there might be a corrupted video file somewhere that make Kodi crash.
                              erpenstine can try some PC software that does auto file renaming, there are some apps that rename all your media like name-season-episode.
                              Then can split all the media files in eg. 5 parts and scrape the 1st part folders and check if there are no crashes playing some of those files, then try the 2nd part folders etc. until you find out what folders/files cause the crashing and remove them.
                              Also try the latest Kodi 18 64-bit nightly as older versions might also have bugs with scraping perhaps.
                                Hi mo123,
                                is there a specific reason why you don't implement the T8C power in your Roms?
                                This would offer a complete new experience in speed and power for your Roms...
                                Thanks in advance
