I thought we dispelled the 'cheap components' narrative when it came to these devices long ago. Among the RK3368 they're all comparably built. Many, many firmwareb builds, and endless amounts of testing and debugging solely focused on performance tuning with demonstrable results has led me to this conclusion; all my firmware releases have a primary focus on performance, above all else, so I'm not speaking out of place here.
HPH NT-V8 RK3368 Marshmallow ROM by mo123
I can run whatever benchmark you'd like on my LL firmware running on Z4 and match it against whatever 'premium' device runs Nagrace firmware, MM, N, doesn't matter, and I can guarantee it'll score 15-25% better in the RAM categories, conservatively.
That's AnTuTu 6.3.3 run on a $50 Z4 with LL firmware, 5.1.1. (run like a day ago, and I can run it back, to back, to back, it always scores the same)
Your firmware running MM on Nagrace boxes cannot match that performance. Wouldn't it be ridiculous, though, to claim that it's because Nagrace boxes are 'inferior and use cheap components'? It's especially bogus when you've never inspected them side by side in the first place. It's all biased speculation.
The 'inferior component' performance gap in RK3368 boxes is a myth at best, biased conjecture at worst.
Let's all try to be a little more objective and reasoned with the advice we impart.
Guest
Originally posted by Shomari View Post
It has nothing to do wth 'slow, unstable ram', mo123 is incorrect and doesn't even own the Z4.
Mo123's firmware is built specifically for Nagrace devices, so it follows that it won't run correctly, if at all, on the Z4, due to differences in component configurations, etc.
I have two Z4's I use for testing, they knock the socks off any RK3368/S905/S912x - especially in the ram department. It's not about component selection, it's about firmware, firmware matching, and configurations on a per-device level.
GuestÂ
It can be because of the device getting too hot and the heatsink or cooling is not adequate.
Check if you can put a bigger heatsink on or use a USB fan if possible.
You should also test the power supply to make sure it is stable or use a new one with 3A output, not the cheap ones usually shipped with tv boxes that have half the actual output that's written on them.
Originally posted by dincis1 View Post
You did a great job with your fw, its very fast. But when i was watching iptv , box switched off couple of times . What is the problem, what do you think? Mostly i use my z4 for watching iptv.
It won't shutdown due to throttling or heat. One of the f first things I did when constructing the cpu hack was to disable RK's throttling controls; in other words, there's no framework for the system to shut down based on cpu heat at all on my builds. Believe it or not.
If you'd like you can try my next update, it's better tuned in many ways particularly for playback, but Mo123 is spot on about the power supply recommendation.
(pardon the thread pollution Mo123, I'm out)
Hi Mo ,
i flashed 1.2 with System from 1.3 and it works even the MTP Mode pops up 5 Minutes
after flashing , if i remember good this not happend on last 1.3 .
But i flash back the 1.3 to check it for Bugs then you can make your Rom again something
better . I report what i find and send it to you by txt.File and Screenshots .
have a nice Day
gefattern
Originally posted by gefattern View PostHi Mo ,
today i downloaded the 1.3 again , with the same Result . The File was again 1.03GB big /
32MB more like you sayed . This can not be normal , or ??? Why it is bigger then 971MB ,
i really cant understand it !!!
nice Day
gefattern
If you check on the bottom statusbar in Window Explorer, My Computer it shows the size in MB.
If you right click the file and choose properties, it will also show the size in bytes tht will be different.
Hi Mo ,
please read Post #208 & #209 on Page 14 there are the Infos you need ,
even Bug/error Infos .
First the AudioRouting works great now , no double Sound anymore .
Mo if i listen to Music and make a Screenshot the Music gets 50% louder
for a sec. or so . I tried to mount two USBDevices one in the stock Port beside
the OTG & the other in the OTG Port but only the "beside" mounted . Thats what
i found in the last hours of course the reported Bugs from #208/#209 too .
There are still some small corrections with Translations , but this i will send
you with ScrSHots. & txt.File in PM within a few Days .
The System runs really good only stupid this strange "PowerOff" Bug on my UT4 ,
until now nobody else reported something like that .
Thanks again for all your hard work until now , have a nice Day .
Greetings
gefatternLast edited by gefattern; 13 April 2017, 05:51.
Greetings
gefattern
For the OTG port, did you disable connect to PC in the Settings - USB
otherwise it won't work.
OK
of course i did not , i try and report , yes it works now , did not know it , thanks .
Mo can you say anything about the Size Problem with the latest Rom ??? ,
and why the Box stays running after Shutdown (Fan/bluePowerLight) ???
thats all first , have a nice Easter .
Greetings
gefattern
Hi Mo ,
first of all , i can not find the "Startpage""Start-Launcher" entry in the Settings , like
in the Roms before . I forgot to report this last Days . You dit not delete that , or ???
One more Translation , for the Reboot Menu , please use "Schlafen" not "Schlaf" ,
and a Screenshot of the "@2131...." Reboot Frame ??? Error :
://www.fotos-hochladen.net][/url]
with the Corrections and small Fixes the next Rom shall be great .
nice Day
gefattern
nice Day
gefattern
I looked at the HPH launcher translations and the days and "nicht verfügbar" is already translated correctly.
I think the launcher might only be optimized for Chinese and English languages and have trouble with others.
So now I think the Ugoos launcher might display German better.
I sent you the translations, that you can just check if they are correct.
There are currently 3233 users online. 2 members and 3231 guests.
