HPH NT-V8 RK3368 Marshmallow ROM by mo123
    On KitKat it was easy but Google increased security so much, I don't think a fully working solution is available.
    The only working way is to patch the app itself or look on xda forum if someone didn't upload a modified app perhaps.
    on tronzid rom ionix patched kernel https://mega.nz/#!XcIGVKBC!g9KsetZlz...MrtHNkuGJHZvLA
    i don't know if can work on marshmallow
      Hi Mo ,
      thanks for answer , maybe i have to install an APP like PPP Widget to get them running i dont know , but i can set the Modems with "Putty" on PC to "Modem only Mode" .
      How to put the "Stock" back i do not know exactly . Maybe some other Users with unchanged 3G Modems can test it ???
      Until now there is only a Recovery for the Geekbox RK3368 ??? not for other RK3368 Devices ??? Bad for us . I think on XDA are Users with Knowledge of Xposed and
      Recovery for RK3368 .
      I can not say much about "passtrough" i only have 2.0 or 2.1 Stereo , my Devices are connected over a HDMI 1.4 Switcher to TV , the TV is Connected by optical Wire to
      my old Thypoon 5.1 DD/ DTS Device , that delivers the Sound to me . I always test the Notification Sounds if i install a new Rom to see if Sound works , if i choose them fast
      enough the Sounds dont cut off a part off it self , but if you wait 2/3 seconds you can hear the cut offs and a clicking like the Line closes , like the Sound Settings in Kodi or your
      NTMC explain , there is a Option to hold the Line for 1 minute , 10 minutes , never or always , i think you know what i mean , and this must be the same in Android , you always
      hear a silent click when it close . If this can be fixed would be nice , if it can ???
      The only thing i miss , is since KK i, a working "Equalizer" , the Bass is a little to hard set if i listen to Music . Thats all i can say about Soundproblems.
      Thats all nice Day to all
      gefattern
        I'm just testing the HPH NT-V8 Marshmallow ROM V1.0 by mo123 with Belink i68, so far everything is fine.
          New firmware v1.1 released
          See OP for details.
          - Latest video framework for improved video playback for h264/h265
          - Added Pass-through settings
          - Updated apps
          - Updated NTMC v16.1.5
          Add AVS video format support
          Optimize audio track switching
          Added surface rendering changes
          - Updated to the latest Timezone data
          - Added wired Xbox remote file
          - Fix system stutter caused by usb audio
          - Fix audio stutter with high disk usage
          - Improve the hdmi nlpcm mode for HD Audio
            Ok!!!works!stuttering nowhere to be found!I tried your resource
            One can put a kernel?
              See OP for details.
              - Updated apps
              thanks for all mo123 , you know if i rename to update.zip and place to racine will work or it's only flash ? i don't want erase all application ... :-(
                Will most likely cause a bootloop if you change parts of the firmware and will loose lots of optimizations.
                  Use MiXplorer's app screen to backup all your apps.
                  For Kodi use it's backup addon to easily backup everything to a zip file or the cloud.
                  Then you can restore easily next time.
                  I havn't checked updating the firmware on the device itself yet and if it works.
                    Spreadsheet with lots of HD Audio videos to test the pass-through capabilities.
                    Please read the OP of the settings to set for pass-through to work correctly on Marshmallow, it is different than for Lollipop firmware.
                    If some people can complete the spreadsheet, it will help to see what AV receivers work the best and what devices have some problems.
                    Then the results can be combined into one spreadsheet.
                      Mo123 boot.img.  No LAN..   Kernel.img?
                        Mo123 boot.img. Â*No LAN.. Â* Kernel.img?
                        You will need a new full boot.img for your device, there is no kernel partition.
                          Hello, I found the menu to activate the passthrough then I opened kodi and configured for the passtrouth (HDMI) I also try FTMC but it does not work. Terrible acute noise.
                            thanks for all ;-)
                              thanks for all ;-)
                              Also search for a multi app installer, then you can install all your apps in one step automatically without manually installing one by one.
                                Hi Mo
                                first of all thanks for your good work same as on 1.0 all looks good with 1.1.
                                Later i will upload the Translations , i made a N2File with Screenshots so you can see what i mean.
                                The most Translations are to do in the Settings.strings you will see.Hope you can copy and paste it
                                to the right place.If something is unclear with Translations ask.
                                Can you say anything about the boot.img you wanted to make for me ???
                                thats for first all
                                gefattern
