HPH NT-V8 RK3368 Marshmallow ROM by mo123
How do I disable USB Audio? I would like to use a WiFi remote (MELE F10 Pro) and it is going to take over the audio?kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Originally posted by cyber7 View PostHow do I disable USB Audio? I would like to use a WiFi remote (MELE F10 Pro) and it is going to take over the audio?
Settings - About device - Build number
Tap 5-7 times on it.
Then Developer options will be activated.
In Developer options - Disable USB audio routing - Enable this setting
kind regards
Originally posted by mo123 View PostI will release an updated ROM maybe today or tomorrow.
It will be very important for users to test HDMI pass-through in different Kodi's so all remaining pass-through problems can be solved.kind regards
New v1.2 Marshmallow firmware released.
I released in in a hurry so still need to check some things.
Password: nagrace
(Use 7zip to unzip and copy whole mega link to download)
- Improved Timezone and location information
- Increased zoom size for screen, users with 4K tv's please test if you can go fullscreen.
- Improved German translation, check if there is still some big translations to be done
- Fixed Power off shortcut
- Added Navigation bar hide shortcut, long press the ir remote menu key to hide/unhide it.
- Improved pass-through, please test on NTMC, RKMC, SPMC and Kodi 17.
Copy and make 4 sheets for each Kodi to be tested.
Download the test videos in the spreadsheet to test.
Provide as much information as possible.
Make sure your av receiver has the latest firmware installed.
Go to Settings app, blue round one and change audio output device to HDMI Bitstream or SPDIF, for stereo sound it can stay on Default.
In Kodi enable the pass-through options your device supports, speakers have to stay on 2.0, don't change that to 5.1 or 7.1 as that is the way Kodi is programmed.
https://mega.nz/#!cMlBgSiI!GsVLADwqm...omFxpiqed2Ulbs
It will help a lot to see where the problems are and if it is a Kodi setting, old receiver firmware problem, only affects one user or many with the same setup.
Hi Mo ,
of course i will check the German Parts and if needed i report and help for a good Rom.I am indeed excited if the new upcoming Ugoos Roms will fix my strange Wifi Stutters
the On/Off Bugs and the German Translations. !!!!!?????
nice Day
Greetings
gefatternLast edited by gefattern; 11 March 2017, 01:44.
Hi Mo and all others
Whats wrong that it not boot , what kind of Device does Jura46 have ??? , so i dont need to download it for my UT4 ???
Mo if i set the Governor to "performance" the highest Clock of the "big" is 1296mhz , so there must something be wrong , because if i use a other Governor 1501mhz is reached well.
The little looks good he reachs 1200 in performance.Do you think that the 1.2 shall boot on my UT4 ??? Hope it helps to make future Roms better.
have a nice Day
gefattern
There are currently 1926 users online. 1 members and 1925 guests.
