HPH NT-V8 RK3368 Marshmallow ROM by mo123
    Originally posted by shivattaque View Post
    no problem for french, I watch.
    New v1.2 12-03-2017 firmware released
    It fixes Google apps and NTMC/RKMC should have pass-through.
    Please test, remember to put speakers to 2.0 in Kodi Settings.
    RKMC - https://github.com/JamesLinEngineer/...-v7a-debug.apk
    https://mega.nz/#!JF9ykAQL!yspUEAM-T...E-Sz3LakrRjc54
    Other users please also test pass-through.
      Same issue:
      Upload files, for free, securely, anonymously, without limits. @UploadFilesFree
      PLAY STORE OK
        Hi Mo and others ,
        does the rest of the FW work well , default Sound ???
        and Mo can you say anything about the Stock "Android" boot.img you wanted to make for me ???
        have a nice Day
        Greetings
        gefattern
          I flashed V1.1 on my Zidoo X6-pro a week ago ,seemed to work. ( with sd-card not recognized, remote non function). Today I tried to flash v1.2 and failed to find any load device. Replaced the rk3368 box with an older rk3188 device and can be found right away, guess I have to stay with v1.1 for now on. Any possible solution on this issue?
            Same issue:
            PLAY STORE OK
            Please flash this boot.img and then test pass-through again in RKMC, Kodi 17 and 'Video' player.
            https://mega.nz/#!1cFAERjY!BrBwxCJ7g...T-mLt54ra_BAMw
            Change the location of the boot.img by clicking the last block.
            The location in the second column must be 0x00008000 and only boot selected in the first column.
            Click Run to flash.
            Click image for larger version  Name:	Flash_boot.jpg Views:	1 Size:	107.2 KB ID:	635482
              Hi Mo and others ,
              have a nice Day
              Greetings
              gefattern
              Yes, it works very well.
              I'm just trying to fix the pass-through then I will also make a Ugoos UT4 firmware and a boot image for you.
                You can try to see if the firmware v1.2 12/03/2017 works in post #121
                  I can load the v1.2 image using the flash tool but cannot found any load device after pushing the reset button with the power unplugged then plugged in again. Tried with an cs968 for testing purpose ,load device found right away.
                    Hi Mo ,
                    thanks for answer , so it is not important if i use 11.3 or 12.3 Version and why making a Ugoos Version , or did i understood something wrong. Do you mean the Build.prob changes or what ???
                    The most i can do by my self but not the "not parse"Parts , it still says HPH in GoggleAccount , but i am not sure i have to check.
                    have a nice Day
                    Greetings
                    gefattern
                      Are the drivers installed correctly?
                      Hold a paperclip in the reset hole, connect a USB to USB cable to the OTG USB port of the X6 and connect the other end to the PC.
                      Connect the power while still holding in the paperclip.
                      Release the paperclip.
                        Hi Mo ,
                        have a nice Day
                        Greetings
                        gefattern
                        The 12.3 version fixes the Google Play not opening on the 11.3 version.
                        The Ugoos version will have all HPH removed and their apps, so it will be slightly different.
                          Новый загрузочный ОК
                          Waiting for ugoos!
                            http://blog.zidoo.tv/2015/11/how-to-...oo-x6-pro-box/
                            I successfully flashed your v1.1 from the original zidoo firmware, so drivers and flash tool are correctly installed. The flashing steps also OK. I again test it out with the rk3188 cs968 and immediately get device =loader and Id=2 on port2 . Tried many times still not found for the v1.1 device.
                              Try a different USB port.
                              Don't use USB ports on the front of a PC or laptop, use back USB ports.
                                Yes, I tried both the front and back USB ports. Also using another windows PC still cannot connect to the device.
