HPH NT-V8 RK3368 Marshmallow ROM by mo123
Originally posted by shivattaque View Post
I'm sorry but it's the same, we know this is possible because on your old firmware Lollipop 1.6 it's worked.
Hi , I installed v 1.2 in my Zidoo x6 pro . It works perfectly . My main goal is to get Kodi v17 . But in "Adjust video Playback" when set to on start stop it does not work as the video start playing . In NTMC it is working fine . Also I can see only NTMC version 16.1 does it supposed to have 16.1.5 . What is 16.1.5 based on?
Users with SPDIF pass-through say everything works, but they probably only use DTS, AC3.
So it must just be HDMI pass-through with HD Audio(DTSHD, DTSHD MA, TrueHD) that give the noise?
The kernel is almost the same as the Lollipop one and it still doesn't work.
I will try one or two more things and then give up.
What happens when you play the HD Audio videos in 'Video' player instead of Kodi?
This will probably have no effect but try replacing /system/libffmpeg.so with file from here https://github.com/JamesLinEngineer/...brkffplayer.so
Must root from Accessibility Options first to get access to replace the file. Do it in MiXplorer file manager.
Can Wasser R68 MM firmware boot on your device?
Please test if HDMI pass-through is working correctly in that ROM also if possible.
Originally posted by BUGBEAR View PostHi , I installed v 1.2 in my Zidoo x6 pro . It works perfectly . My main goal is to get Kodi v17 . But in "Adjust video Playback" when set to on start stop it does not work as the video start playing . In NTMC it is working fine . Also I can see only NTMC version 16.1 does it supposed to have 16.1.5 . What is 16.1.5 based on?
Every version has new changes from RKMC or other small changes.
Auto frame-rate switching doesn't work in Kodi 17.
That is why I asked in the FTMC thread if someone can help modify RK frequency switcher addon for Kodi so users can install the addon in Kodi 17 to make the auto frame-rate switching work in Kodi 17.
At the moment it is not working and some other changes are still needed.
It would work great if someone can just install an addon to have more control over auto frame-rate switching in any Kodi.
I hope someone will be able to fix the addon as it only works on RK3188 devices on Kitkat firmware at the moment.
If you check in Android Settings Apps, it will show 16.1.5 or in NTMC the date 22 Feb.
Read your post on FTMC , did not know that there is an addon for Frame rate switching . I hope that some one fix it for RK3368 devices .
Keep up the good work I really appreciate your good work . Zidoo team has abandoned the idea for updating x6 pro . It is nice to see your ROM working in our devices.USB OTG does not work in that but I can live with that
Regards
Hi Mo ,
i am still busy with the Translations of the RK3368 de files you send me , i was nearly ready but then the stupid "äöü black sign"Bug came back.But next
Weekend i think maybe a little bit earlier i can send you the files back. Until now i have not tested so much the new Rom , but most runs good.
But why did you not use the German Translations that i send you ??? All was good translated !!!!!!
We all wait for the new Rom and what about Ugoos and the Roms they shall bring ???
have a nice Day
gefattern
It's very strange.
This will probably have no effect but try replacing /system/libffmpeg.so with file from hereÂ*https://github.com/JamesLinEngineer/...brkffplayer.so
libffmpeg.so doesn't work for DTS HD / DD T HD.
Wasser R68 MM Does not yet handle HD sound.
The Beelink February update is the only RK3368 build that has correctly functioning standards compliant HD audio, but it has very bad general performance and especially terrible video performance. I'm like a broken record, but chalk that up to RK's ridiculous RKCodec fantasy....
EDIT: just for info, I tried everything I could on my end to correct the performance/video playback issues while maintaining the IEC audio standards, I know exactly which files to modify/alter, but it was to no avail (you either get proper video playback or standards compliant audio but not both) with current sources. I stress, again, that contrary to what some might think, the January Lollipop sources outperform the existing MM SDK by quite a bit.
I HIGHLY doubt RK is ever going to offer a fully functional, high performing, standards compliant MM build. I was hopeful, but it just doesn't look good unless Nougat drops and saves the day.
Originally posted by scooter2014 View PostYup pretty much sums up my thoughts on rk route.
Doom and gloom, I know; but try if I could, no amount of sugar can put a glaze on this mess. . .
There are currently 2245 users online. 1 members and 2244 guests.
