HPH NT-V8 RK3368 Marshmallow ROM by mo123
    Hi Mo ,
    i received it and will do my best for a good Rom .
    Stupid these Language Problems in the Code . I wonderded i tought i made it good ,
    hope you can fix the Rest .I know the ULauncher not all was perfect and i already tried
    that Ugoos made it , but until now nothing , good that u are there .
    Did you see the Reboot Screenshot ??? this was not correct or ???? @2131.......??? Frame .
    nice Day
    gefattern
      mo123 i tried installing this build on z68. HDMI pass through is not showing in kodi under audio, the surround is not working.
        Use RKMC, I already reported that there is a bug in FTMC to get fixed for pass-through sound.
          Can you share the link how to get RKMC apk ?
            GitHub is where people build software. More than 150 million people use GitHub to discover, fork, and contribute to over 420 million projects.
              Added color change display for people with green / purple screens on old Sony and Phillips TV. *
              Select another color setting for example. * RGB 255 ,,
              Can I add this to the marshmallow?
                Hi jura46 ,
                if you are a Developer sure , but i think you mean if Mo can do this in his next Release .
                I am right ???
                have a nice Day
                gefattern
                  Lastest version will work on a z4 tv box?
                    Hi Koes ,
                    Try , but better go there :
                    http://freaktab.com/forum/tv-player-...k838-tronfy-x6
                    your Devices has a differnt Wifi Chip (i think) , so before you flash ask there once more .
                    There a different Z4 Models please ask before doing anything and maybe brick your Device .
                    Always backup before u flash .
                    good luck
                    en veel geluk ? buurman
                    gefattern
                      Hi jura46 ,
                      I am right ???
                      have a nice Day
                      gefattern
                      exactly! You are not mistaken!
                        Don't know, since the manufacturer (Eny Technology, Acemax ?) has released no Marshmallow firmware for Z4 and abandoned it, no one knows the correct settings to build MM firmware for it.
                        You will have better compatibility using Shomari or cOOLio's firmware for Z4
                          Not one firmware except yours does not have a sound fix in the YouTube. Thank you!
                            Make a kernel for Z4 with a fixed sound and we will all be grateful!
                            Возможно, её удалили или в ссылку закралась ошибка
                              https://cloud.mail.ru/public/DxRH/dw7SuGhbf
                              What do you mean Youtube sound don't work?
                              What was the problem on other devices?
                              It has always worked.
                                Sound stutter and video. You have corrected yourself in v.1.1.
