HPH NT-V8 RK3368 Marshmallow ROM by mo123
Originally posted by gefattern View PostHi Mo
first of all thanks for your good work same as on 1.0 all looks good with 1.1.
Later i will upload the Translations , i made a N2File with Screenshots so you can see what i mean.
The most Translations are to do in the Settings.strings you will see.Hope you can copy and paste it
to the right place.If something is unclear with Translations ask.
Can you say anything about the boot.img you wanted to make for me ???
thats for first all
gefattern
I just have some trouble with the SD Card names, in English they call lots of things like SDCard USB Storage and USB Storage SDCard which is very confusing, so that will not be correct yet.
Some places things are still double but very difficult to fix.
But is it definitely much better than it was.
The Settings2 app I can't translate, tried to do it, I asked RK to check but they will probably take a long time.
Originally posted by stevenchen View PostHPH NT-V8 Marshmallow ROM V1.1 can not use 3840x2160-60p,or 4960x2160-60 and Can not be adjusted “Screen Scale" to fill the TV screen( SONY KD-55X8500D)
Hi Mo ,
nice to hear , i know that the SDCard Names are differnt but the best is u use only three of them 1. SDCard = SD Karte / 2. USB Massstorage = USB Massenspeicher
3. USB Storage = USB Speicher , everybody knows then what it is . Another hint "Brightness" has no Function , so why not delete it too.Why shall it be a Problem for the
System if you only delete the "strings" entries of the double things ??? , so you can see it anymore in the Settings ???
Settings2 is not a Problem for me , i deleted it , you know i always debload the Roms and change the Launcher and Keyboard with my favorite .
Okay on your Rom is not much to debload but on others i always delete 25-35 Apps . Example my KK Rom on UT3 .
I am still busy with the MM DE values.de strings that u send me but takes time have to do it row by row .
Must row 257-263 translated too , some strings about the battery stats ??? Can you say anything about the "boot.img" that you wanted to make for me ???
Thats all first have a nice Day
gefattern
gefattern
Dear Mo123
First of all. thank you very much for your effort to give us a standard ROM for our Rockchip 3368 media players. I have Zidoo X6 Pro. It was a good product but with very limitations beacuse the Rockchip SDK support, so, our 10bit 4K videos can not be played (the bitrate limit 100M. Maximum bit rate of my Lumix 4K are: 106 Mbps). The sistem is very unestable and the AVCHD3D_files (MVC 3D files recorded with Sony 3D Camcorder HDR-TD10) do not play. Hope with your ROOM in the future we can solve this isues.
Best regard.
David
Best regard.
David
For best video playback use NTMC or MXPlayer.
RK3368 doesn't support 10-bit or HDR so it is not something I can fix.
Best regards.
Hi Mo ,
here are Infos about the Time Date Bug , it only corrects the Time when i set the Year to 2017.Even NTPSync does not
work.NTP , says it is changed the Time , but did not , change it.
I had a problem with BT it did not start till i tried it , a few minutes later well , dont know why ???? Is it normal if i pair a
Headset and listen to Music that Headset and Boxes play the Music ??? , must the Music not only heard on Headset ???
Mo small Info for u , i spend several hours with Translations for the Ugoos Roms and they dont even used them for the
new Version !!!! 3.0.9 , does after 7 not come 8 so why 9 .Sequence is not important ???
Thats all and thanks that u use my work ,
have a nice Day
gefattern
Ps : If i know how to i would make my own translated Version !!!!???
Hi mo123, i would like to try your rom in my beelink i68 100M because i have a lot of stuttering... is possible load a fix to have wifi, rename the nvram6330 to 35 (didn't works for me) or something like that ??? ... (i guess that my chip is ap6330)... greetings!MK808B K.I.A.
MK908 Finless ROM 1.7a + Mele F10
CR11S Quickshot V3.1, 720p kernel @1,7GHz, GPU600, DDR720 + Mele F10
MK902 Quickshot V3.1 1080p @1,8 GHz, GPU 600, DDR720 + Mele F10
GT-I9505 OMEGA ROM
There are currently 1417 users online. 0 members and 1417 guests.
