HPH NT-V8 RK3368 Marshmallow ROM by mo123
    Hi Mo once more ,
    I can report that the "PowerOff" Button in the NavBar does not work on my UT4.My AirMouse "PowerOff" works , Reboot too , i can not use my favorite "Rootexplorer" it always stops working.
    Maybe the APK supports not the MM API ??? or somthing else ?
    Looks like there are Problems with the "mnt"media_rw" Folder , can not reach the connected Devices over it , only over "storage" it works.I looked into the "permission.xml" File there is only one
    Permission for "WRITE MEDIA STORAGE", not two more like in KK or LP. Will the SDcard Fix App from Playstore help ??? (tested with MIExpl. & EZFileExp.)
    I really missed the Function to hide the "NAVBar" not only "StatusBAR".
    i already deleted the "Bootanimation.zip" because i like the "ANDROID" Bootscreen , but the "Nagrace" still exist but i have a UT4 . Can it be deleted ??? or changed ??? by a Tool ???
    Mo remember i only have 3G Wifi Router with a 5GB Dataplan i can not test all Things in the same Way like others.
    Its late and i have to do a break
    nice Day
    gefattern
    for status bar you can use this app ,it's work great for me :-)
      Hi natzen ,
      thanks for Info , i know this APP , but i prefer a Settings option or do it by "build.prob".
      Does anyone already tested "Xposed Installer" i really like Gravitybox with Piecontrol.
      Mo really makes good things.Some bugfixes and then perfect.
      nice Day
      gefattern
        Hi
        Hi natzen ,
        nice Day
        gefattern
        Hi
        In the opening post I already told how to hide the navigation bar easily
        Hiding the navigation bar
        - Root your device(also see opening post), then open the /system/build.prop file with eg. MiXplorer.
        Change ro.rk.systembar.tabletUI=false to ro.rk.systembar.tabletUI=true
        In this case the Recent menu key on the IR Remote won't work any more(because of different fullscreen window sizes) but home, back etc. will still work.
        Having only 5GB data can't be good
        I hope my firmware don't use it up and you still have left to use.
        I'm collecting feedback since it will be too time confusing to make a new ROM just for 1 bugfix, so waiting to do more once.
          Hi Mo ,
          thanks for answer and the hint with the "Navbar" i always used "qemu.hw.mainkeys=?" , to hide it.
          No Panic i always test Offline or with a Firewall that not all Apps connect to Internet.
          Mo what is with "Xposed" can you say anything about it and can i use the TWRP Recovery for LP5.1 RK3368 that
          i used before ??? What about the "media_rw" Folder Problem what i reported before , would the "MM SDFix" App
          If i tried to open up a Device over "media_rw" MIExp. always ask to "gain permissions" as i did that , the UI of the
          Download App pops up.Bug ??? or only a second opinion from System ???
          With the Translations i begin in a few Days , the HPH i must do new , i deleted the old ones , but Mo i am sure i
          send you Translations for it only for LP5.1 i think RK3288.
          Yesterday i debloated and changed the Launcher , today i try "Root Browser" because my Favorite "RootExplorer"
          dont work on MM its Ver.3.1.2.
          nice Day
          gefattern
            Hi
            Hi
            thanks for all ...on zidoo box we have 2 ubs port (1 otg usb) and otg usb not work you know why?
              Hi Mo ,
              i had to flash my UT4 once more , because of "GooglePlayServices" crashes all the Time and so i was not able to add my Playstore Account.
              Today the MiEx. makes no Problems with the "media_rw" Folder , i was able to open the SDCard with it .Strange.
              later more
              nice Day
              gefattern
              PS : Mo is it possible to use and add the Translations offline if i download "NET.Framework 4.0"
                Hi Mo & all others ,
                First of all i want to say that you Mo made "GREAT WORK" the Rom runs before & after i configurated to my needs , really smooth.
                Internet (Chrome) , Music & Videos that i tested was all good , even with my not so fast Internet , Youtube played the few minutes i
                tested a 1080p HD Video without Problems.
                I am not sure but i think i found a double Systemfunction in the Settings.If you go to "Display" there is a "Cast" Function and in
                "Sound&Notifications" is a "Cast" Function.
                I downloaded "NET.Framework4.0" installed it , but i can not use the Tool , it always says "Enter valid Path" . I did it like described.
                Dont know whats going wrong with it. I do it the old way.If i send u a txt.File you can copy and paste it into the right position of the
                strings.xml or where ever it must be.
                Root Browser works good . Now i only have to test if my PS3 Controller works , i hope it works well.
                If i found something i report.
                have a nice Day
                gefattern
                  gefattern
                  What Windows are you using?
                  I used Windows 8 but think Net framework was already installed by Windows Update by itself and didn't get any problem.
                  If you change the strings.xml file manually, you can use Notepad++ to do it since other apps can corrupt the file then I can't use it.
                  Just do the main translations that you can see that are wrong or need improvement when using Android otherwise it would take a few days to do everything.
                  You can make your own txt file also.
                  Then I can use the important translations first and later if there are more, then can do a small update again.
                    Hi Mo ,
                    okay i try , but can u say somthing about Xposed and can i use the TWRP that i used for LP ???
                    I use W7 32bit Ultimate. / is "Cast" double ???
                    have a nice Day
                    gefattern
                      Hi Mo ,
                      Until now i had only two Apps that made Problems ; Rootexplorer and Catlog , both not react.Maybe no MM support ? I dont know.
                      I made a first View because of Translations 99% is good only a few things still to translate like "Ethernet" and some other parts.
                      But the Clock makes Problems , after every Reboot the Time is changed.Now it was 4:05 / 24H Format / after Reboot / 20:05 .
                      Only online it turns back to the right Time.
                      have a nice Day
                      gefattern
                        Hi Mo ,
                        have a nice Day
                        gefattern
                        Because tv boxes don't have built-in batteries like PC's to save the time, you need to be online to get the correct time.
                        Some expensive tv boxes have built-in batteries that can keep the time without an internet connection.
                          Hi Mo ,
                          but UT4 has RTC , it has a small Batt. inside and why the UT3 has not such Problems and the Time stays same ???
                          Now its to dark for a Picture i make one in Daylight to show you the RTC Batt on UT4.
                          Something other strange i connected a Fan to the Connector , at the Moment the Box is open , placed him beside the Board ,
                          did not spend much Attantion for a Moment , the Fan falls to Board only on a Corner , but now the Fan becomes no Power if
                          i connect him again. The Fan works still i tested him. Can it shorten the Power Settings to OFF ??? Really strange.
                          What about Xposed and Recovery ??? can i use them ???
                          once more nice Day
                          gefattern
                            I have not found the place where it finds Hdmi passthrough setting in android options?
                              Hi Mo ,
                              once more nice Day
                              gefattern
                              If you can see the name of the RTC battery or find out from Ugoos, I can add the driver then maybe the time setting will be remembered without internet access.
                                Originally posted by shivattaque View Post
                                It should happen automatically the HDMI pass-through when using NTMC or Kodi 17.
                                Also update the firmware for your audio receiver if it has updated firmware.
                                Then enable pass-through in NTMC or Kodi 17's settings.
                                Please let me know if it works.
                                I'm still trying to find a way to add the sound settings.
