.. that's normal - interactive will actually be likely to get you better performance on firmware with factory cpu settings, as that's what the tunables and firmware is set up for.
HPH NT-V8 RK3368 Marshmallow ROM by mo123
Originally posted by shivattaque View PostSorry but 1.2 does not start.
Blocked image nargrace.
wait 30mn 2 times
(i68G)
New link posted for Marshmallow v1.2 ROM
Because the previous file was too big, sometimes it caused problems with boot.
See the Opening Post for details.
https://mega.nz/#!8NtxxY5Y!pCy0HxGqG...x93H0kIDKgQLy4
Pass: nagrace
Please test pass-through with this spreadsheet
NTMC : http://pastebin.com/Qn6dwz8H
(smal part)
Kodi 18 Master : http://pastebin.com/nZnStGSm
SPMC : http://pastebin.com/4KzfMV6t
AUDIO TEST FILES PLAYBACK COMMENTS BAD GOOD GREAT OTHER 1 Dolby Digital Plus 5.1 x 2 Dolby Digital Plus 7.1 Channel Check 3 Dolby TrueHD 5.1 x litle song, cut,cut, cut, cut, 4 Dolby TrueHD 7.1 Channel Check 5 Dolby ATMOS 'Amaze' Demo 6 Dolby ATMOS '747' Audio Demo 7 Dolby ATMOS 'Helicopter' Audio Demo 8 DTS-HD HRA 5.1 x litle song, cut,cut, cut, cut, 9 DTS-HD HRA 7.1 10 DTS-HD MA 5.1 Channel Check x litle song, cut,cut, cut, cut, 11 DTS-HD MA 5.1 24-bit 192kHz audio-only sample x litle song, cut,cut, cut, cut, 12 DTS-HD MA 7.1 Speaker Phase 13 DTS-HD MA 7.1 'Dredd' Audio Channel Check 14 DTS:X 'All Around Us' Demo x litle song, cut,cut, cut, cut, 15 DTS:X 'Gravity' Demo x litle song, cut,cut, cut, cut, 16 DTS:X 'Movement' Demo x litle song, cut,cut, cut, cut, 17 LPCM 5.1 x 18 LPCM 7.1 19 AAC 5.1 20 FLAC 5.1 24-bit 192kHz audio-only sample 21 DTS 5.1 x
Log:
SPMC
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
Kodi 18 Master
NTMC
(just a Litle part)
Originally posted by shivattaque View Posthttps://ufile.io/75b95
Log:
SPMC
Kodi 18 Master
NTMC
(just a Litle part)
Did you set HDMI Bitstream in the round blue settings app?
'Keep audio device alive' in Kodi's, try to set it to always
'Sync playback to display' - Turned off
Please try again with SPMC and then each time with the 3 different Android Audio output settings in SPMC - Android PCM, Android IEC, Android RAW
And then those 3 settings in combination with - 'Passthrough output device' Android IEC & Android RAW Passthrough.
So it will be 6 different combinations.
Exit SPMC fully and then change to another audio output and test again.
Your testing will help a lot.
I'm very close to solving the problem I think.
The spreadsheet was also updated.
But no need to do all the tests if nothing works at the moment.
I will make some small changes to the ROM and then you can use the spreadsheet for the new updated ROM.
ICE Test:
RAW test:
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by shivattaque View Posthttps://ufile.io/9d6af
Here is a video to see what happens on my amp with DTS HD Master more test soon.
I put together some pictures to help.
You can test on Kodi 18 and SPMC if it makes a difference.
I found a bug in NTMC's log so pass-through won't work there. I will upload new firmware soon to see if that bug is fixed.
Screenshots from SPMC 16.6.0 but can do the same in Kodi 17
'Enable Dolby Digital (AC3) transcoding - That causes problems if you use HDMI Pass-through. It is only meant for users that use SPDIF optical pass-through.
Speakers must always be 2.0 It is the way the new IEC61937 pass-through was designed and implemented by Kodi 17/18 and Google.
Keep audio device alive - 'Never' works best but sometimes 'always' also works
'Sync playback to display' - Must always be turned off for pass-through to work. In Kodi 18 I think this setting was removed.
You can test on SPMC 16.6.0 and maybe this time try Kodi 17(http://mirrors.kodi.tv/releases/andr...-arm64-v8a.apk) instead of Kodi 18 nightly.
\Here are the log with your settings/
Kodi 17 (x64):
Kodi18 Master (x64):
SPMC 16.6 (x64):
The results are identical, Apart from the small difference in Kodi 17 you will see on log (DD+cut):
Originally posted by shivattaque View PostBut I forgot to say that the remote control works for switching off and on the box, but Google Play does not work.
(The LED remains blue when the box is switched off).
I will upload the new ROM soon so you can test NTMC, RKMC that should work the best I hope.
Originally posted by shivattaque View Postok
If there are a few things to improve, you can send me screenshots and a text file of better translations if needed.
Or if you are using English language then it is okay.
I'm working on finishing the new update then you can test it later.
I will also try the latest Google apps as I see it has a problem.
There are currently 2732 users online. 0 members and 2732 guests.
