HPH NT-V8 RK3368 Marshmallow ROM by mo123
    Originally posted by shivattaque View Post
    Same horrible noise.
    libffmpeg.so doesn't work for DTS HD / DD T HD.
    Wasser R68 MM Does not yet handle HD sound.
    I thought so.
    The R68 MM firmware is a lot older than mine and have the same HD audio problem.
    Strange thing is on the HPH RK3229 MM firmware, HD Audio all work with no problems but RK3229 devices use different sound codecs.
    Unfortunately no one has released updated RK3368 MM firmware or SDK updates.
    Geekbox just took a 'bye bye users' we leave you with our last broken MM code, but thanks for your money.
    Now we can only wait for Firefly to release the new code from RK to fix all the RK3368 problems and backport it.
    Maybe Jide can also help with future Nougat firmware that they develop for RK3368 and it can be used for other devices perhaps.
    Lollipop firmware is still recommended to have working HD Audio.
      Hi Mo ,
      on my UT4 Wassers Rom can not boot it powers down after a few seconds.
      have a nice Day
      gefattern
        Hi Mo ,
        have a nice Day
        gefattern
        The Beelink, Tronsmart R68 devices are very different(hardware) and for some reason their firmware don't work well or can't boot on HPH or Ugoos devices, so not recommended to try that.
          Hi Mo ,
          i restored all my Apps on my UT4 and it looks like the Time (only the Time) comes back if you set the Date to 2017 ,
          Date is still wrong. 1.1 did both after that.
          After that i tried NTPSync but it failed then i activated "Automatic Date&Time" and the right Time came up.
          A Test before that "Automatic Date&Time" changed it did not work.So Date&Time it is not fully debugged.
          Translations are nearly ready for sending back.
          have a nice Day
          gefattern
            Hi Mo ,
            i think tonight i can send you the RK3368 Files back to see if all is translated good , i really hope .
            Why you not only make a system.img with it , that i can flash and control it on my Device , before it will be used.
            have a nice Day
            gefattern
            Last edited by gefattern; 20 March 2017, 14:09. Reason: Â* why this always comes up in text if i save aThread
              Hi Mo ,
              here are the german Translations for your Rom , please use both Launcher and System ,
              only so i can say if all is good now .
              Translations.zip
              we all wait for your new Rom ,
              have a nice Day
              gefattern
                I need some people to post logcats(catlog, syslog apps work good) of Rockchip stock 'Video' player app when using HDMI pass-through.
                  Hi Mo ,
                  i made some Logs while i used the Box , with "LogcatExtreme" the App "Catlog" always runs stuck and says "it dont react wait ..."
                  Does "Catlog" run on your Device well ??? I used Ver.1.6.0. / if you want i can upload them , maybe it helps you ???
                  have a nice Day
                  gefattern
                    Hi Mo ,
                    have a nice Day
                    gefattern
                    You can try with SysLog app.
                      Hi Mo ,
                      i tried differnt LogApps like Logcat , i am more interested why some Apps like LogCat/Rootexplorer and others dont work and make this "dont react"Bug.
                      I think "Syslog" works , have to try.
                      nice Day
                      Greetings
                      gefattern
                        I fixed some of the pass-through problems on RK3229, RK3288.
                        Will see if it also works for RK3368.
                        Now I have to finish 3 different firmwares.
                        Some user also said when he plays audio with bluetooth it still played through the tv speakers and bluetooth speakers.
                        I will also fix that problem.
                          Hi Mo ,
                          i had the same Problems while using a Bluetooth Speaker , that is right.
                          nice Day
                          Greetings
                          gefattern
                            Hi Mo ,
                            nice Day
                            Greetings
                            gefattern
                            I will release a small update today to
                            add the German Translations, fix bluetooth audio and add sleep mode.
                              Hi Mo ,
                              Nice.
                              Greetings
                              gefattern
                                Ugoos ? when?
