HPH NT-V8 RK3368 Marshmallow ROM by mo123
It should happen automatically the HDMI pass-through when using NTMC or Kodi 17.
Also update the firmware for your audio receiver if it has updated firmware.
Then enable pass-through in NTMC or Kodi 17's settings.
Please let me know if it works.
I'm still trying to find a way to add the sound settings.
Sorry but it does not work in Hdmi passthrough.
I tested with NTMC and FTMC.
It works with ROM HPH NT-V8 ROM V1.6 (Dolby Digital et DTS) but no Marshmallow. (on HPH NT-V8 ROM V1.6 no DTS HD Master / Dolby Digital True HD option)
My equipment: (http://fr.yamaha.com/fr/products/aud..._g/?mode=model)
Hi Mo ,
i tried to delete the first boot Picture "Nagrace" , but i failed , tried it with Sergio Poverony latest Tool , deleted the Pic , but after build and flash it was still there.
Dont know how to do it.Can you help me with that ??? i want stock "Android" Bootscreen.Maybe you can build one and upload ???
Here is the Pic of the Batt :
Last edited by gefattern; 19 February 2017, 18:14. Reason: wrong Info cant delete Nagrace Bootscreen
I know you just want the box to not say Nagrace because yours is a Ugoos machine, and not for any inappropriate reasons.
Hi Shomari ,
i really think Mo has no Problem with that , but for sure you can ask him ??? if you want.
I will be very happy if i could Boot without this PIcture only "Android".
I tried but failed i think Sergio Pov. Tool does not Support RK3368 even if it extract it.
Shall i upload a extracted "boot.img" from Mos latest MM for you ??? , or do you have the FW self ???
thanks for Help
gefattern
thanks for Help
gefattern
Will finish v1.1 MM ROM tomorrow.
Just waiting for Rockchip to fix the new RKMC.
Hi Mo ,
thanks i wait , then i can use it for higher Versions ,
if not to much is changed .
I already made Screenshots for the Translations.
Used your Note2 , but when i open up one of the Files
the German ö,ä and ß in the words are shown in strange
black Signs.Can i use WordPad for it ???
i tried a Geekbox/Github RK3368 Recovery but they did
not work , no Boot into it.Stuck on Nagrace Boot.
nice Day
gefattern
nice Day
gefattern
Just check if the characters don't make black signs.
That was a problem with the Lollipop translations then I had to replace the black characters with the correct ones which was very difficult to do manually.
Rockchip fixed the new RKMC problems so that is good news then I can maybe finish my new firmware today.
Hi Mo ,
once more , i tested the 3 Huawei Sticks that i have S4011/E1550/K3765 non of them can be used under "more" "Cellular Network" or "Data Plan" .
If i press "Cellular Network" it stops and closes , after that it goes back to Settings . "Data Plan" says i have to insert a Sim , but maybe it does not
work because i flashed my Sticks with "MobilePartner" Software ???? , but i dont think so .Until now i do not use them anymore , but it will for sure nice ,
if that Function would work too . Maybe you can delete to the next Version already the double Entrie "Cast" like i discribed some Threads before .
Can you say anything about Xposed and Recovery , please , i already ask two Times ???
Hope it helps to make future Roms better , good Work , go further ,
I really cant understand my strange "Vodoo Fan BUG" how can this happen ???
nice Day
gefattern
nice Day
gefattern
The usb_modeswitch utility should switch the modems into CDC Ethernet mode instead of mass storage.
But I'm not sure how to check it for your 3G modems.
Can you get the stock software back on them instead of MobilePartner software to test again if it works?
I couldn't get Geekbox recovery to work, I will try to find a different one and test.
I try to build my own Xposed from source code into the firmware but run into some trouble, so will only test that later again.
I have to translate another app today then will try to finish the firmware today.
Was too busy testing new RK3229 things and the latest RKMC.
The new firmware will also have an easier way to set pass-through correctly for HDMI and SPDIF, I hope it fixes the problem some people had.
If someone has pass-through problems and want to test a solution before the new firmware is released, PM me.
These 2 modems are supposed to work correctly I hear, Huawei E5573 and E3372.
Originally posted by natzen View Post
thanks for all your work ,if it's possible to patch hdmi detect for hbo and other app ... i don't know if it's possible .
The only working way is to patch the app itself or look on xda forum if someone didn't upload a modified app perhaps.
There are currently 2046 users online. 2 members and 2044 guests.
