HPH NT-V8 RK3368 Marshmallow ROM by mo123
    Hi Mo ,
    i restored all my Apps , while first try restoring my Apps with TB the Device made a green screen ,
    after unplug and new start the rest of restore was okay , no problems .
    It looks like that Death Trigger2 stil has problems with this Rom , after playing one Game and going
    back to the Hideout , the Game stocks every 1-2 Seconds for 1-2 Seconds , so it can not really be used
    and must restarted . Only first Gameplay runs well after that stocks , but the "wont react" Message ,
    does not pop up so much anymore . Same with Unkilled , but not so much as before . The Govenour
    is performance .
    Before i forget it once more , the stock Reboot Menu , the Reboot is still English and must "Neustarten"
    same with the pop up that follows after u press Reboot . "Reboot""Your Device will reboot" must be
    "Neustarten" and " Ihr Gerät neustarten ?" .
    I know u made this nice Reboot App , but i prefer the stock Reboot , but really you made a nice looking
    and running new Rom .
    I thought about the Storage translation problem "SDCard from ..." in German , if we cant find it in the
    Settings.strings what about the App "externalStorageProvider" or similar , maybe it is there to find ,
    same with "install from SD" for Certificates .
    " What would all the Guys do , if there where not a Guy like you "
    thanks to Mo and his always great work and support . Hope my Hints help to make a really good
    working final of this Rom . Will there be a UT4 Version too ???
    have a nice Day
    greetings
    gefattern
      Hi Mo ,
      WoW even the HDMI CEC works , i can now use my TVRemote to navigate the System ,
      you really made good work Mo once more GREAT WORK .
      nice Day
      greetings
      gefatttern
        I'm working on a new ROM again.
        I think most things like HDMI audio, HDMI CEC now work.
        Any other bugs, can let me know.
          mo123 You are AWESOME and your software is AWESOME!
          kind regards
          cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
          http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
            Hi Mo ,
            nice to hear , hope you solved the German "Bildschirmaufnahne" to "Bildschirmaufnahme" with m ,
            this was the last Error i could found . Even HDMI CEC works now with my other Devices , now i can
            use my TVremote to navigate the Box and my TVReceiver Remote can now handle the Volume ,
            before i had to use my learnable AirMouse with Keyboard to handle the Volume of the Soundsystem .
            Really great work
            greetings
            gefattern
              Hi Mo,
              I have issues with your latest rom. The keyboard not always pops up upon clicking on fields in Chrome browser. Maybe it could be fixed on your next rom? Thanks!
                Hi Andro James ,
                did you try to clean cache and data , you know you can change it to any you want , if you have root .
                My worked good even after changing it .
                nice Day
                gefattern
                  I have a couple of questions.
                  1 Is there a TWRP recovery that works for this ROM? I tried to install Followmsi's TWRP_RK3368_3.0.2-1 but no recovery....
                  2 How to disable on screen keyboard?
                    Hi quincydog ,
                    TWRP i think not , i could not find one , too . The screen Keyboard i think under
                    Language & Input / Keyboard & Input Methods , good luck . Please report .
                    gefattern
                      New Superspeed MM ROM v1.5 released here
                      pass unzip: nagrace
                      - Super fast
                      - Onscreen keyboard improvements
                      1. Fixed keyboard to work with IR remote
                      2. Disabled annoying key clicking sound by default (enable the sound in Android Input Settings under the keyboard if needed again)
                      3. Blue highlighted key color instead of white
                      - Option to disable onscreen keyboard if using an airmouse or bluetooth keyboard
                      (Go to Language and Input Settings and change the default keyboard to 'null keyboard')
                      - Improve network performance
                      - Fix HEVC in MKV files not always playable
                      - Fix playback for mkv files with lacing
                      - Limit ogg packet size
                      - RGA2: Fix BGRA stride
                      - New RKMC with 3D shortcut
                      (Can also use latest SPMC Krypton as RK3368 don't use advanced features like other soc's)
                      - Ad-free Youtube
                      - Write to external storage
                      - Improved gamepad support
                      (Please test if PS3/4, Xbox USB/Wireless remotes work, need to pair certain remotes a specific way)
                      - Improved ad-blocking in browsers
                      - Fixed German Bildschirmaufnahme spelling error
                        Nice work Mo123....
                          Hi Mo ,
                          as always your are the GREATEST , Thanks , hope it runs well .
                          Could you improve the Ram usage ???
                          Wow nice Keyboard extra . Shall try if i could download it and
                          report .
                          greetings
                          gefattern
                            pass unzip: nagrace
                            - Super fast
                            - Ad-free Youtube
                            Hi mo123
                            I concur, this is a SUPERFAST rom!
                            Just 2 things :
                            1. Why did you not post this on page one? It is going to get lost in between all the other posts...
                            2. How do I get the weather on the front page to work?
                            THANK YOU again for your wonderful support and roms! It goes a long way to blow life into this amaizing box!
                            kind regards
                            cyber7 (aka Aubrey Kloppers; South Africa)
                            kind regards
                              Hi Mo ,
                              flashed your Rom , first of all , nice work .
                              but i think you forgot to translate some of the thing we talk over Threads and PMs before , not really a World Crash , but it would be nice if this
                              can later be fixed with 1.6 . I already took Sreenshots and will add a txt with Hints for better spelling or corrections , like we did before .
                              I really like the stock Android Bootscreen , what about an "non" Nagrace" boot.img for Users with other Boxes and the Box boots a little faster .
                              I shall upload the "txt" if i am ready with restoring and testing of my Box . How does it goes with your N7 Project ???
                              have a nice Day
                              gefattern
                                Hi Mo ,
                                have a nice Day
                                gefattern
                                OK, you can send it to me then I'll fix it.
                                I'm busy with V6, N8, N9 firmwares too.
                                The RK3288 firmware was finished but I added some more things and ran into a bootloop, so hope I can fix it now.
