HPH NT-V8 RK3368 Marshmallow ROM by mo123
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Then I will have to make lots of changes to try to get it to boot on this specific device, every RK3368 box uses different internal components and drivers.
Every OS update also brings new problems that didn't exist before.
I will only know when RK finishes Oreo and I start to build new ROM's for RK3368, RK3328 if it can work.
Android 8.1 for RK3368 will be released around end of Jan 2018 if RK keep to their schedule.
You and your ROMs are very special! I hope nothing happens to you and you are prosperous for many years to come!kind regards
Would love to see Oreo on my Alfawise. But won't cry if I won't.
Still this statement by Ugoos is only to distract attention from them. RK3288 started with 4.4, so 6.0 was goo accomplishment for nonQualcomm or Exynos chip.
And it was probably coz of Google's choice to not allow update to 7.0+ for devices with GPU without support for Vulkan API (they broke that rule with update for first gen Android One). So it would make RK3288 on the same level as Qualcomm 800/801.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostWould love to see Oreo on my Alfawise. But won't cry if I won't.
i did not even know about these things , Vulkan API ..... , thought Android is open source ???
greetings / gefattern
Hi ,
And as global manufacturers (global meaning more important) of the devices won't update them (coz of no possibility to include GApps), than there is no need for components' (mostly SoC) manufacturers to support newer Android versions, as they won't be sure if it make any profit (they won't get paid for unofficial Roms).
That way, of course indirectly, Google can control Android, even as it's "open source". However being open source, it's possible for devs to create unofficial updates. However if You look into most know Roms (Resurrection Remix, Carbon, LineageOS) You will se that they don't include GApps (they have to be flashed separately). That way there is no problem with missing Vulkan API and need for permission from Google.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
firmware here:
https://drive.google.com/file/d/1GqI...ew?usp=sharing
file system firmware tablet P10 here- lib GPU support Vulkan API
https://drive.google.com/drive/folde...Ce?usp=sharingLast edited by BEN001; 10 January 2018, 18:46.
Originally posted by Andro_James View Post
Yes, I understand this. I thought that just because this fw is for rk3368 device, it could still be installed on TV box just for testing
Hi Mo123 ,
the Problems i had with my UT4 where made by RKMC , after uninstalling it the Box worked much better .
You know i always change the System Launcher to Apex Launcher , but if i boot up the System Launcher
always first must start , can this be changed ??? , and i found two more spelling Errors , report later what
i mean , first have to look once more .
What about the RK News about Oreo for RK3368H , will this be possible for our Boxes too ???
Have a nice Day / greetings / gefattern
kind regards
Aubreykind regards
There are currently 2228 users online. 1 members and 2227 guests.
