Flashed this firmware on my Z4....it rocks...thanks even though it was not made for my device...So far the only thing that happens is on occasion the screen would turn black and will not come on even with mouse movement...I have to reboot....all settings are checked to keep display on always..using a 5v 4a power supply...and a screen always on app...still...anyone else experiencing this?
HPH NT-V8 RK3368 Marshmallow ROM by mo123
Hi all,
maybe a little to much Power , what about 5V/3000mah Powersupply ???
good luck / gefattern
gefattern
There is no such thing as to much power when it comes to power supplies... Sometimes the PS gives lower voltage then 5V (4,8 or less) and this can cause instability in some cases (depends on the boxes Elektronik).
hoodafukisalice
You can try Apex, its similar to Nova witch i use with no problems on my Z4..
Originally posted by jit18 View PostYou can try Apex, its similar to Nova witch i use with no problems on my Z4..
Originally posted by hoodafukisalice View PostLike you yourself said, Apex is not very different from Nova launcher. I asked if there is an alternative launcher meant for TV boxes, like Zidoo's own launcher for the X6 Pro.
I thought Nova didn't run well on your box, that's why I suggested Apex.
Originally posted by minixfreak View Postdoes anyone have the resource file i could flash to this rom .... i need i68 ap6330 .... needs to work with this rom
https://drive.google.com/file/d/1iFk...ew?usp=sharing
Originally posted by minixfreak View Posthow do you add an ir remote with rockchip ? i need to program my i68 remote into this firmware any help would be greatful or can someone make a simple file i can just flash with this rom to ir works ?
for this i think you have to change the "Keylayout File" , somewhere here is a useful Thread ,
but without your Stockfile from the i68 it will not work , because you need this values .
Maybe you can get some Infos here :
and if you want you can upload your Stockfile here :
Hi
I will check if I can add it but it might be difficult as code is hex and source code use decimal numbers that is completely different, you can't just add it as it will cause bootloops.
But will have to test it first if there are no negative side effects if I can get it to work.
I don't like to overclock the CPU as it doesn't provide a sufficient performance increase and degrade lifespan of devices.
Overclocking the RAM, VPU has a far greater increase in overall performance and video playback.
Lifespan degradation - in this context - has been, in my experience, a myth. From HMP tunables to frequency scaling, OC'd systems can be structured for longevity, more than some may think.
I've yet to kill a device by overclocking.
Still have the two RK3368 Z4's I've used for testing, with one still running daily duty on a set.
First thing.... WOW YOU'RE ALIVE!
Second thing... I still have my MK808b running on performance mode at 1.5Ghz... (RK3066!)
Iam not even sure on what kernel it runs because I use a KENT ROM from "mother russia" forum.
Let's be honest those socs are made to last forever... and if we still lower their lifespan at half by overclocking them their still gonna outlive us...
I understand overclocking more like fine-tuning a car.. It's not just putting more fuel in it (well that too) it's altering the Wright parameters so that it performs best!
minixfreak It's not gonna work that easy by just swapping a file for another..
Mo123s Roms are very special...
There are currently 3818 users online. 1 members and 3817 guests.
