what is T8C power ??? , never heard ??? greetings / gefattern
HPH NT-V8 RK3368 Marshmallow ROM by mo123
Hi ,
T8C is the acronym for True Octa Core...
Meant is the ability to run all 8 Cores at full speed simultaneously , in case of rk3368 8x1,6 GHz instead of 4x1,2GHz and 4x1,5Ghz.
True Octacore means actually 8 Cores in a single die.
Shomari used this expression (T8C) to describe his achievement to run the RK3368 at 2x4x1,6Ghz and that's what i meant.
Greetings jit18
Originally posted by jit18 View Post
Oh, I thought it was commonly known..
Greetings jit18
thanks , of course , i know from Shomari and his full 8 running Cores , the short description confused me ,
dont know if Mo123 ever wants todo this , would be a nice extra to his great Rom . Thanks / gefattern
Hi Mo123 ,
i found a still existing spelling Error in German , under "about Device" "Compability" , the "nur" Error
still exist .
Wrong "Diese Firmware ist für den Einsatz auf offiziellen Nagrace HPH RK3368 Android TV Boxen nur ."
Right "Diese Firmware ist nur für den Einsatz auf offiziellen Nagrace HPH RK3368 Android TV Boxen geeignet ."
I hope you will fix this in a later Version , any news about this ???
have a nice Day Mo123 , greetings / gefattern
still exist .
I will update that.
Will also provide a small improvement for passthrough audio.
Greetings jit18
I will check if I can add it but it might be difficult as code is hex and source code use decimal numbers that is completely different, you can't just add it as it will cause bootloops.
But will have to test it first if there are no negative side effects if I can get it to work.
I don't like to overclock the CPU as it doesn't provide a sufficient performance increase and degrade lifespan of devices.
Overclocking the RAM, VPU has a far greater increase in overall performance and video playback.
Hi
What do you think of this method?
While Coolios Rom has low 3D scores in Antutu his UX and CPU scores are amazing...
This trick is easier as you do not have to disable all the security checks etc
The ap6330 resource would be nice but I use this workaround in the meantime. Some versions of this Rom won't allow it though. I forget off hand which ones work and which don't, sorry. http://freaktab.com/forum/tv-player-...ap6330-chipset
There are currently 3850 users online. 1 members and 3849 guests.
