[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
I've installed this on my S905_MXQ_100_V02 works great a little slow but maybe it's updating the apps. The wifi works everything seems to work. The problem I have is when I try installing Netflix it doesn't work I get a 500-XXX error code and when I install other versions my box restarts and just keeps restarting over and over again. I tried using aptoid to install and I get the same error when it opens.
What build of Netflix works with this rom?
How can I access the bootloader? I tried holding the reset button with a toothpick and plugging in the power but i can't seem to get into the bootloader to reset to factory.
Could it be because im powering the device with a usb to usb cable?
The power issue was due to a faulty power supply it's no longer on a boot loop. I found a Netflix app that works with this build if anyone is interested. I had to restart the box a couple of times but it finally worked. You need to make sure the time and date are correct otherwise no Netflix app will work.
You need to go to upgrades.montrealandroidtv.com click on the grey button that says GO TO REPO then click ANDROID then download all three and try them to see which one works for you. I tried the ones for Android TV OS but they didn't work on my box. cOOLio
my MXQ PRO 4K is stuck in this.. i wanted to reflash coolios img but the AV button doesnt do anything anymore. i dont know why is that. i tried the Usb Burn Card. but since the AV button isnt wporking i cant do it too. im attaching a picture where i am stuck
the mouse is moving. its working
but its stuck in there. no laucnher.
just the mouse. thats right after booting.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by gepol View PostHello. I have a MXQ Pro 4k with CPU S905 and board p201. I tried Coolio's firmware but my WiFi didn't work because I have ap6181 chipset. Is there anyway to install drivers for my chipset or when I can find correct firmware for my tv box?
Originally posted by p.khoi View PostI registered an account to thank you cOOLio. My box works perfectly on V2.5 MEE (MXQ Pro 4K -S905-4GB Rom-1GB Ram). Your Rom is very clean and stable. Your Rom has saved life MXQ box 3 years old. Great! Thank you very much!
Thank's for coolio, I have the same box and all is ok.
wifi rtl 8188etv
The firmware of the AM2 v1.1.1 android 6.0.1 is also great but the wifi nor ethenrnet doesn't work ... Are here a pro to resolve this problem for us ???
Thank you
Originally posted by SirMcFrosty View PostIs there any chance that c00lio will revive our S905 Boards (MXQ Pro) with a new firmware?
There is an firmware with Android 6.0 and it runs smooth... but it lacks drivers for ethernet and WiFi ...may be we can combine our power to include some realtek drivers and make andoird 6.0 work for our boards.
proove and a bit deeper look you will find here: http://mxqproject.com/mxq-pro-s905-a...pdate-sort-of/
Anybody who is a bit more into Android and Rom development would help a lot (i am pretty sure i can help with test and error search as a it professional but i am clearly the microsoft corner regarding OS, ROMs and such ...yes yes windows is meanwhile dead on mobiles i know)
THX in advance
yes I have tested the firm of AM2 with andoir 6.0.1 and it's very nice and smooth but ethernet and wifi :-(
So if anybody can do it for the community ...
Thank's for all
Good day, Coolio
Please may you send me a direct link to
[ V2.5 MEE - Missy Elliott Edition ]
Comes up with access denied to google drive link.
Have a MXQ Pro 4k S905 tv box.
Or is there anyone who can assist me?
There are currently 1848 users online. 1 members and 1847 guests.
