[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
    Hello Friends,
    Please help me unbrick my box by flashing Coolio or find the right firmware, information below and board photos (attached)
    MZY Extreme Pro 4K
    Amlogic S905XQ v2.0
    WiFi SV6051P
    1GB/8GB
      Originally posted by LovelyRock
      Love the firmware, but after a day or so from installing it, my mxq pro 4k continues to freeze, lags, or gives a stuttering sound . I need suggestions.
      Me too
      I try to build one without Coolio optimisations, seems to affect somes boxes....
      Envoyé de mon MHA-L09 en utilisant Tapatalk
      Beelink MXIII II (ATV)
      Apple TV
        Hello Friends, hope you can help me
        yesterday tried flash this rom on my mxq pro 4k s905, first try something went wrong and it got stuck on 2%.
        Read some posts so tried again uncheking bootloader erase box, so it went until 7% than got stuck and I pressed reset again and it continued until 100% and got successful installation, but when I connected the font again it is white red light, tried flash again but it always stops in 2%... probably I bricked my box, can someone help me to unbrick it?
        has someone had some problem?
        need help
        thanks in advance
          Using the latest version on Mx8 Pro.
          I have an app (Airtel TV) that stuck in portrait mode (stretched) and because of this am not able to watch TV in full screen mode. I used a couple of orientation fixing apps to set the mode to Landscape.. but that does not seem to help. Can anyone please help?
            Hello, I am using this rom in a mxq pro 4k, it works fine, but I found a problem; in many applications, you can not see the icon of the menu to make the settings of the application, for me it is very important, since I use applications like tasker, to automate the system.
              Hey! Im loving this on my mxq so far...im just curious how do I get TWRP installed from udisk or SD card?
                Ok so I managed tp get this up and running! So far So good! LOVE IT!!!...i"m curious though. can we change the LeanBack Launcher to something else? im not sure im a big fan of the android tv GUI..could i install the Pixel Launcher or Nova Launcher etc?
                  I can't seem to locate a reset button anywhere on my box, I took it apart to have a better look and there is no button behind the AV, anyone have this problem?
                    Hello, I have an MXQ PRO 4K with Rockchip RK3229, I would like to know if this is compatible with my box and if I can flash with an SD. If not is there an alternative that will make my box much more stable than it is now? Thanks in advance.
                      HI LIO, my device is mxq plus, and run your room like a charm. But there is one thing I want to figure out, I download and install youYouT kids from apkmirror for my baby, but I can just install the Armv7a, the 64bitA8a version can't be installed. As I know, S905 is base on armV8a, so, why does that happen?
                        Will it work on p212 board?
                          Nope - p201 only
                            You need to adjust your screen size from settings. On my TV 92% is perfect.
                              That had already done but it did not work
                                I would highly appreciate if someone can help me. I am trying to update my box but cannot find correct info.
                                My model is " Nexbox MXQ PRO" but doesn't state 4K on the box.
                                So I am not sure will this ROM work for me. How to find out, shall I open my BOX?
