[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
Strange thing I notice today is there is no way to boot into flash mode. I was running Libreelec form an SD card and was able to boot to TWRP from SD card by toothpick way, but that doesn't work anymore. Not sure if when there is an update to this ROM I will be able to upgrade cause with toothpick trick just go to full boot up.
I have a tv box Transpeed CX 919 Mini s905 WIFI Modul RTL 8189FS, after restoring, flashed with different firmware without problems, stock and others. But WIFI does not work. In the settings it does not turn on. Delivered your firmware, really liked (V2.0 SSE V2. 5 MEE) but WIFI is not defined! Help!
So I buyed an USB male/male. I did everthing as you told but my PC didn't recognize the device, I mean it didn't even noticed I plugged in the device. I thought it was problem of the USB but after trying I did make it: Just plugged the usb+the AC cable+ pressing the reset button everything at the same time and boom, it did work. Thank you alot!!!
Great work cOOLIo.
I see there is finally 6.01 Marshmallow firmware for the S905 - actually for the Ugoos AM2:
Android 6.0.1 Firmware V1.1.1 for AM2 Android 6.0.1 Firmware V1.1.1 for AM2 440.33MiB
Any way for people to port this to a P201 MXQ Pro- flashable zip/img we can start work on a Marshmallow ATV ROM for the P201 MXQ Pro, or cOOLIo are you able to work with this?
Originally posted by Lucaseaux View PostSo I buyed an USB male/male. I did everthing as you told but my PC didn't recognize the device, I mean it didn't even noticed I plugged in the device. I thought it was problem of the USB but after trying I did make it: Just plugged the usb+the AC cable+ pressing the reset button everything at the same time and boom, it did work. Thank you alot!!!
Originally posted by Wildwind View Post
You don't need the AC plug pack for firmware flashing. Press the Start button on the software and plug the USB cable into your box with the reset button pressed and the whole process should start
Btw, I tried to install the xbox 360 wireless controller drivers. I think there is a guide online i tried already but something was wrong and didn't recognize the ".ko" files. I ended up messing up my remote control "select" button and had to reinstall the firmware again. I really would appreciate if you add xbox 360 wireless receiver drivers in the future. I think you have to add "xpad.ko" to "system\lib\modules".
Originally posted by Badfrogg View PostThe IR remote did not work for me (MXQ PRO 4k S905) Cant seem to figure out if there is a way to fix that or not.Attached Files
Originally posted by Badfrogg View PostIm trying. Don't really understand the file permissions. cant just simply copy and past... Thank you though for the direction.
The other option is to decompile the IMG using Amlogic Customization Tool, and replace the files, and then rebuild the image, then flash to the box.
Just not having any luck. Cant seem to change the file permissions that would allow me to replace those files and when I tried to do it the other way by unpacking and repacking the img file with the amlogic customization tool, it end in an error that says ""Failed to pack images to complete image" (I did try to read the manual but it was a bit confusing)
Its funny because I've been trying to get this box to work for a year now and now ROM will full work. and I dont know what I'm doing otherwise so... yep, I suck!
Originally posted by Badfrogg View PostJust not having any luck. Cant seem to change the file permissions that would allow me to replace those files and when I tried to do it the other way by unpacking and repacking the img file with the amlogic customization tool, it end in an error that says ""Failed to pack images to complete image" (I did try to read the manual but it was a bit confusing)
There are currently 1584 users online. 0 members and 1584 guests.
