[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
    So ive done this upgrade and the browser always crashes before i even get a chance to install any addons, im trying to put my old factory firmware back on the box via usb burning tool. and now it wont stay connected. computer recognize it then disconnects. and obviously the factory reset button wont do anything because everything has been forced erased. Im i screwed or is there somthing im missing?
      Thanks for the great work is 2.5 still te latest version?
        hello please someone knows how to activate accessibility options in android 6.0 marshmallow in a tv box with rk3229 and SV6051P wifiChip.
        I want to use the buttons remaper application to remap buttons on my remote control but in the accessibility services option it says "there are no accessibility services".
        in another rom of android 5 if they appear but in the 6 no longer probe with several rom of android 6 and do not have the option
          Can anyone help me
          I have MXQ PRO nexbox and i would install this Rom without PC cause i don’t have needed cable so can i install IT without PC
            Originally posted by petardam View Post
            Can anyone help me
            You can install it using Burn Card Maker found at the following link.
            You'll need an sd card though.
            Once you copy the image to the SD card using Burn Card Maker, restart the box in recovery.
              How to restart box in recovery mode
                If I recall, there's a button in the AV port on this box. Use a toothpick to push it when you turn the box on.
                  Thanks and do you know can I install it with usb or it have to be SD card
                    You can try, it's never worked for me. Only SD card has worked for me.
                      Ok, Thanks
                        Will Microphone from MX3 remote work on this Rom
                          Hi I have 2 questions:
                          1. How I can add a application in the main list of application.
                          2.. Why I can not found on PlayStore a Netflix Application? Netflix is one of the main application that I use.
                            Hello, first of all thank for this great ROM!
                            I have one problem since this morning. Everything went great with 2.5 version but this morning when I turn box on, logo show up for a few second and then box restarted. This is going on and on. I thought that it is cooling problem with sensor - I unplug it for few hours and still same. It is same when I connect it to PC, switch to recovery (USB burning tools finds box for a few second and then release it). Even SD boot doesnt work. I dont know how to stop it from restarting
                            After booting logo MXQ appear for a few seconds and dissapear. This repeat over and over again.
                            When I manage to flash ROM again it doenst help. I tried also version 2.0.
                            I have MXQ-S905-D16.
                            Thank you for advice!
                              excelente aporte
                                Are there any non TV versions for the mxq pro?
