[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
    Originally posted by cOOLio View Post
    I'm not much into DRM, i believe in open source.
    But to give you any more help I need more infos. Because "I have a problem" says nothing to me. I need details, as much as you can give.
    The exact error message, at leas a screen shot if you got any on screen error message. Or much better, a ADB log file from the moment the error occurs.
    Here you can get ADB for Windows. On my MXQ I was not able to use ADB over USB. So I used the WiFi ADB app instead. And here you will all infos about how to use logcat
    The log adb during the error
      Wow ! Tnx Coolio ! Kernel - super )))))
        After my first custom ROM for the Z4 RK3368, I decided to make my next rom challenge with my already dust covered "bricked" S905 tv box.
        ... and BOOM ... now this lame duck is a pretty solid low budget android
        TV box.
        Custom ROM ( image / firmware ) for the MXQ PRO 4k - p201
        stable . fast . clean . leanback ATV . custom rom
        This custom rom mod is based on the UGOOS AM3 V0.0.7 TV firmware
        Important Note
        This ROM has already driver of the following Realtek WiFI chips included
        • RTL8188eu ( >> works << confirmd by Milchen83 )
        • RTL8189es (BOARD MODEL: MXQ-S905-D16 VER:1.0 DATE:151021)
        • RTL8189fs (only V2.0 SSE)
        • RTL8192eu
        • RTL8723bs
        • RTL8812au
        My p201 Leelbox has the RTL8189es WiFI chip. So i can guarantee you it is working with that one. If you got another version of the MXQ PRO p201 box, that has one of the other Realtek WiFi chips build in, give it a try.
        And please let us all know if this ROM also works for you. (exact BOX version & WiFi chip) THX
        It is a fully Google android TV rom with the following features:
        • International leanback keybord (long press OK for special characters)
        • Voice search support (use USB MIC)
        • easy ROOT (#SU) via UGOOS advance settings
        • Fully IR remote support
        • easy edit for Gampad settings
        • Samba (SMB) Network file server (for easy APP sideload)
        • App Drawer (for easy start of non ATV apps)
        • Autoframerate
        • Enhanced IR Remote Keys Click image for larger version Name:	remote.png Views:	1 Size:	122.4 KB ID:	639302
        • etc...
        Known issues:
        • No support for Wireless Assistend (Fireasy / Firefly) from UGOOS settings
        Some screen shots
        Google leanback android TV launcher (home screen) Click image for larger version Name:	MXQ PRO 4K - ole androi tv.png Views:	1 Size:	241.2 KB ID:	637018
        Additional settings (ROOT, Fileserver, Gamepad Settings, Wireless Assitent (does not work), Voice Input) Click image for larger version Name:	MXQ PRO 4K - special features.png Views:	1 Size:	26.5 KB ID:	637016
        Clean ROM (all bloatware and unneeded services are already removed) Click image for larger version Name:	MXQ PRO 4K - clean rom - 3,6 GB free space.png Views:	1 Size:	28.9 KB ID:	637015
        Long press power button (sleep, reboot, reboot recovery) Click image for larger version Name:	MXQ PRO 4K - long press power button.png Views:	1 Size:	92.7 KB ID:	637017
        How to install Click image for larger version Name:	install step 01.PNG Views:	1 Size:	11.4 KB ID:	637019
        Click image for larger version Name:	install step 02.PNG Views:	1 Size:	15.3 KB ID:	637020
        Click image for larger version Name:	install step 03.PNG Views:	1 Size:	79.5 KB ID:	637021
        Click image for larger version Name:	install step 04.PNG Views:	1 Size:	19.6 KB ID:	637024
        Click image for larger version Name:	install step 05.PNG Views:	1 Size:	194.6 KB ID:	637023
        Click image for larger version Name:	install step 06.PNG Views:	1 Size:	154.8 KB ID:	637022
        NOTE: The preinstall process on first start is finished after Opera Internet Browser is visible. Click image for larger version Name:	Screenshot_2017-04-02-01-50-28.png Views:	2 Size:	119.0 KB ID:	639292
        App Drawer (since V2.0 SSE)
        Change log
        V2.0 SSE (Slim Shady Edition)
        • fixed a boot issue (wrong kernel thermal cpu check)
        • added additional WiFi driver for RTL8189fs
        • updated WiFi driver for RTL8188eu, RTL8189es, RTL8192eu, RTL8723bs, RTL8812au
        • added the following functions for the non used IR remote keys (TV CONTROL)
          [ power = play/pause | vol+ = skip | vol- = rewind | TV IN = stop | SET = music | SETUP = search | APP = bookmark ]
        • added „"App Drawer"“ to home screen. (easy start of side loaded non ATV apps)
        • added new apps & google ATV services like: aptoide TV, AirPin, Gamepad Tester, Terminal, ATV Customization, Landscape Wallpaper, ...
        • updated all google apps to the latest version (date 170402)
        • removed ATV launcher for dlna/AirPlay & Miracast (start them via App Drawer)
        • removed all BT settings and files
        • serveral other small fixes & enhancments ...
        V1.1
        • fixed some kernel issues during boot
        • cleaned up kernel init from not used garbage
        • reorganized and optimized apps to speed up system boot & app load time
        • updated all google apps to the latest version (date 170321)
        • fixed voice input for non leanback ATV apps
        • added google text to speech to enable voice on search results like weather forecast / who is questions etc.
        • added ATV launcher for Amlogic dlna & AirPlay service
        • added ATV launcher for Miracast service
        • re added stock LatinIME keybord to re enable language & input setinngs @More settings
        • removed all firefly files because of missing kernel drivers (but it is still in settings)
        • re added BT settings to kernel init (if someone wants to try to get BT working if board supports it)
        V1.0
        • inital port from UGOOS AM3 V0.0.7 TV firmware for MXQ PRO 4k p201
        DOWNLOAD
        The needed USB Burning Tool and this guide is already included to the ROM download file.
        [ V2.0 SSE - Slim Shady Edition ] [ link 2 ]
        [ V1.1 ]
        [ V1.0 ]
        For Tips & Tricks to speed up this ROM check >> this post <<
        Hints on using a Gamepad with this ROM can be found >> here <<
        Check also >> this thread << for tipps on free of charge IR remote friendly (ATV leanback) apps.
        Did not work on my transpeed s905 2G 16G wifi rtl8189e, gave infinite boot
        Last edited by bluesmanuk; 16 April 2017, 11:17. Reason: Translated to English. https://translate.google.co.uk/
          Hi Coolio,
          I tried your rom on my beelink mxiii (s905, 2g, realtek wifi) because I wanted to really do everything with only a remote (waf issues lol) which can not be done with regular android.
          But I had some problems...
          I can only connect via wifi, it doesn't seem to see my rj45 cable connected : quite a problem for "real"hd movies which lag on wifi.
          Even with the original remote.conf in etc I can't get the remote to work.
          The framerate switch is perfect but audio passthrough doesn't work for me.
          I keep an eye on here in case of a update, thanks a lot for the work done.
            Hello, The buttons on the remote control for :
            Does not work when I press the keys
            Can you help me
              The problem is solved
              Install myCANAL TV by CANAL_v3.0.1.3 to remove the problem of drm
                Can you help me
                Lol .. these cheap chinese boxes are so different, even when they look like the same. Looks like they don't change this shit even not for the remote control.
                Here you can find a full instruction on Redefine any Keyboard, Gamepad, Remote Control key.
                BTW, Play, Pause, Forward and so on, will ony work in case the apps (like Kodi does) support this key features.
                My contributions to the community
                [ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
                [ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
                  @ All others who are trying to install my ROM other boxes then the MX PRO 4k p201 box, I made this rom for.
                  In case my ROM it is not working at all, or some things are not working for you. Sorry, I can't help you anymore. No time at all, for this. As I mention already in this thread. This ROM was only a lessen learn side project to me. But feel free to use my ROM as a base of your own S905 port. So that it works also with you box/stick.
                    Thank you
                      HI! i have a generic box with the same specs that have the mxq pro 4k has amlogic s905 and p201 board, should this rom work on it?
                        I have the Transpeed mk809v plus amlogic s905 2G/8G and this rom worked amazingly.
                        Just have a few concerns.
                        1. Can I disable the voice search. It tries todo it in almost every app
                        2. Can I get the full usability of my RAM. I have 2G and its says I've got a total of 700 something MB
                        3. Is there a way to access the button that brings up settings. I like using Advanced task killer but cant configure it because there are no options
                          My mxq pro does not have the reset button (AV hole) or at least it does not have it in that place. Would it be possible to flash the rom via adb or sd-card?
                            I've given your firmware a go on my MXQ Pro 4K (P201).
                            Impressive work. It will give these old boxes new life. I was able to run a lot of stuff usually reserved for Android TV.
                            That said, here's what to expect vis-a-vis real Android TV devices (like Nvidia Shield)
                            Netflix for Android TV (4K) - This requires heavy DRM so don't bother sideloading the Android TV versions. Stick to the mobile version (480p limit).
                            Live Channels - minimum Android 6 required so you can't integrate the channels into 1 app with Episode/Program guide
                            App switcher - only available on Nougat for Android TV
                            PIP - same, also available only on Nougat.
                              After a little puttering, this build doesn't allow write access to USB drives.
                              I followed this link to allow it;
                              When you've got an Android media player or mini PC, you may want to connect an external USB drive and allow write access to this drive to some
                              I use torrents on my android tv boxes (to replace my old HTPC setup) and this worked quite nicely.
                              Maybe you can include the change in the next iteration.
                                Yes that is possible in serveral ways.
                                1. If your ROM hasent root check first this instruction to get ROOT, via ADB (WiFi) should work on any S905 device.
                                  Then start googeling on TWRP images for S905 devices and test them, until you find one that works to flash my current ROM image file
                                  Here is an easy video instruction, on how to install/uninstall any custom recovery like TWRP on your device.
                                2. Short PIN 29 + 30 with a needel of your Nand Flash Memory, to activate Masked recovery Boot Modus (in theory the same what the rest button makes)
                                  I had to do the same once with my MXQ Pro Box, to flash a nother rom once. Because the rest button was disabled by the Stock ROM
                                  Note: Every NAND Flash has a small round indent, in one of its corner to show PIN 1. PIN 29 + 30 can be found with the help of the picture below.
Name:	Bildschirmfoto vom 2017-03-27 00-29-03.png
                                3. Soft Brick you device totally, then It will go automatically to NAND Flash recovery mask mode.
                                  I did this once by mistake, cause my dog disconnects the power cable at that moment the NAND Flash was totally wiped. First thing that happens when U update a Stock ROM via SD card method. So not the what I want at the moment, but I realized than that this will also bring your box to NAND Flash recovery masked mode.
                                Much luck and fun
