[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
Originally posted by thenut2014 View PostThanks for the help. It works great. My only issue is my Logitech F710 gamepad will not work. Is there anyway to get it to work on this rom?
And what do you mean by it will not work? Are the buttons only mixed up, or is it not deteced by android at all?
Did you check already the pre installed app Gamepad Tester? There you can also check if you gamepad is detected or not.
To test just press a button or move the analog sticks.
Originally posted by dimas18 View PostDoes the cast service works?
I got only a old hacked version, but it was from the benning very buggy & choppy, and since Google changed the Google service Framework, it will no longer detected by the youtube app.
So no Google Cast service included, only DLNA & AirPlay.Last edited by cOOLio; 09 April 2017, 15:59.My contributions to the community
[ ROMs ] Z4 RK3368 - android TV (ATV) | MXQ PRO 4K - p201 - android TV (ATV) | Yundo Y1 S912 - android TV (ATV) not yet released
[ Tutorials ] Bootup logo Amlogic S912 devices | Redefine any Keyboard, Gamepad, Remote Control
Originally posted by dimas18 View Postwell, opera browser is not working well, i changed to another one
It's your Box, you can install/uninstall whatever you want.
And in addition to my previous Opera comment, I have to add the following.
In case U use only the IR Remote Control, Opera is the best ATV Browser you can get at the moment. And that says a lot about browsing the internet in these days on a TV. Because still the best ATV Internet Browser is a piece of crap.But in case U use a AirMouse or Keyboard with Touchpad, you can install also Chrome, Firefox, etc from the Play Store. But without a AirMouse, etc, these non ATV Browsers are even more worst to use with the IR Remote Control only. And in case U install Chrome, you will notice that it is only available at the App Drawer. Because it is not a ATV app. But attached you will find a small apk that adds also a Shortcut to the Home screen to start Chrome directly from there.
Googlechrome_ATV.apk
By the way, I created the ATV launcher APK with the help of this web page: http://atvlauncher.trekgonewild.de/index.php
So in case you install some other non ATV apps, you can create your own ATV Home Screen shortcut.
And in case you unistalled Opera already and you want it back. You can find the installer still at /system/preinstall folder on your box.
Originally posted by dimas18 View Posthow can i change the default launcher, it is fast but kind poor of custumizations
This is forced by Google, not me. And this is a Google android TV (ATV) ROM.
And one final thing about the Google leanback ATV launcher. The first time I used it on my SONY 4K, I had the same wish. Get rid of the Home screen launcher and install one of them You already use on your tablet, mobile and android box. But it wasn't possible, so I start using it. And what should I say. Right now I understand why Google made the decision to force us to us it on a TV. It's a perfect leanback concept. Just leanback to the couch, with your tiny remote control and enjoy watching movies. And when it come to typing, just talk instead of using a keyboard. Its much much faster and it works mostly pretty well.
So It's up to you. If you don't like it. Nobody forces you to use my ATV rom. But I'm pretty sure you will get friends, when U start using it. And as more users start using a ATV device, as more ATV apps we will get. Because when I start using my SONY 4K TV in 2015, those ATV apps where pretty rare. But in the last few month, there are more and more new available at the Play Store. And I also notice on my own behavior. If there is a good non ATV app , where I still have to use my Rii mini Keybord. I stop using it on my TV and start searching for comparable ATV app.
this rom is my favorite, it works perfect, its what what i need, many thanks
Originally posted by cOOLio View Post
I know, but I did you check already this post?
[ATTACH]n640611[/ATTACH]
You can install as many other launcher as you wish. But non of them will work on a Google ATV.
Your welcome & much fun with your new ATV box.My contributions to the community
Hey there.
Before I'm gonna start tampering with my device, I'd like to double check if this ROM is meant for it.
My stick is Transpeed S905 MK809V as seen on the product page below.
More detailed specifications:
Model: Amlogic AOSP on p201
Revision: r0p4
CPU: 4x ARM Cortex-A53
GPU: Mali-450MP
Android 5.1.1
Kernel architecture: aarch64
WiFi chipset: 8189eh (Realtek?)
Thanks in advance!
P.S. Also, how would I go about making a full backup of my current ROM, just in case?
Hello,
This rom is beautiful
Thank you very much
However
The application netlix android tv does not work on this rom Https://play.google.com/store/apps/d...ix.ninja&hl=en
It's normal ?
However, this version mobile works: Https://play.google.com/store/apps/d...iaclient&hl=en
The mobile version of netflix works but it does not stream video in hd
thank you for your help
Originally posted by Cappie View PostThe application netlix android tv does not work on this rom Https://play.google.com/store/apps/d...ix.ninja&hl=en
Originally posted by Cappie View PostHowever, this version mobile works: Https://play.google.com/store/apps/d...iaclient&hl=en
Your welcomeMy contributions to the community
Thank you for your answer
I also have a drm problem with the mycanal application: https://play.google.com/store/apps/d...id.canal&hl=en
There is a solution ?
The application running on the original rom
Revision: r0p4
GPU: Mali-450MP
Android 5.1.1
Thanks in advance!
To make a full backup of your ROM, you need ROOT and a working TWRP recovery on your device.- This instruction to get ROOT, via ADB (WiFi) should work on any S905 device.
- Then start googeling on TWRP images for S905 devices and test them, until you find one that works to backup your current ROM.
- Here is an easy video instruction, on how to install/uninstall any custom recovery like TWRP on your device.
Originally posted by Cappie View PostI also have a drm problem with the mycanal application: https://play.google.com/store/apps/d...id.canal&hl=en
But to give you any more help I need more infos. Because "I have a problem" says nothing to me. I need details, as much as you can give.
The exact error message, at leas a screen shot if you got any on screen error message. Or much better, a ADB log file from the moment the error occurs.
Here you can get ADB for Windows. On my MXQ I was not able to use ADB over USB. So I used the WiFi ADB app instead. And here you will all infos about how to use logcat
I'm not much into DRM, i believe in open source.
"erreur DRM
Attempt to read from filed 'byte vt.b' on a null object reference "
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 1776 users online. 0 members and 1776 guests.
