[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
Originally posted by PaulieP View Post
Originally posted by Badfrogg View PostIm trying. Don't really understand the file permissions. cant just simply copy and past... Thank you though for the direction.
"Replacement-Wireless-Original-Android-TV-Box-Remote-Control-MXQ-PRO-4K-M8S-PRO"
Originally posted by Wildwind View Post
I had the same problem and it still did not after I replaced the remote.conf with the correct one. May be I need to replace the ug_remote.conf file instead. What is the ug_remote.conf for? I ended up buying another remote from China which worked with the firmware and hence no more fiddling around with the remote file
Originally posted by Badfrogg View PostThe IR remote did not work for me (MXQ PRO 4k S905) Cant seem to figure out if there is a way to fix that or not.
I just dont know linux so I dont understand how to change permissions. thorough a command line I guess. I guess you need some kind of app for that. Terminal something and then type some commands... Guys. just be honest, I a moron and I should just buy a Fire TV from Amazon like morons do, right?
Originally posted by Badfrogg View PostI just dont know linux so I dont understand how to change permissions. thorough a command line I guess. I guess you need some kind of app for that. Terminal something and then type some commands... Guys. just be honest, I a moron and I should just buy a Fire TV from Amazon like morons do, right?
I appreciate that you are trying to help me, i really do, but it is just not working. I cannot move or copy or do anything in the etc directory. I dont know how to get "root". I guess that means Administrative powers of some kind... When I search "Change Permissions in Android" or "Root Android"on google I get command linux style command prompt type of instructions. I dont get how I'm supposed to get into a command prompt with an Android TV box.
I bought this box a year ago and I have loaded 3 or 4 different ROMs on it, that part is easy, just follow the simple instructions, but there are no simple instructions for doing what you are trying to tell me to do. No ROM that i have tried has made this box useful. Either the network doesn't work or the remote doesn't work or nether work.
Originally posted by Badfrogg View PostI appreciate that you are trying to help me, i really do, but it is just not working. I cannot move or copy or do anything in the etc directory. I dont know how to get "root". I guess that means Administrative powers of some kind... When I search "Change Permissions in Android" or "Root Android"on google I get command linux style command prompt type of instructions. I dont get how I'm supposed to get into a command prompt with an Android TV box.
Originally posted by Done View Post
You have to go to Settings -> Ugoos settings -> System -> ROOT and click Install Root. Then just open ES File Explorer, select Root Explorer on the left side scrollbar and then you can edit file permissions just by visiting the properties tab of each file.
The only ROM that i have found to work with the remote is NEOMOE's but then i dont have any network with that ROM.
At this point, the amount of time spent, it is just not worth it. This box is gone to the junk bin and I'm going to take my life back. Thanks every one for helping. Hope all your hacking goes well. Peace
Originally posted by Done View PostReplacing ug_remote.conf didn't work with any of the two NexBox .conf files. I have also changed file permissions to match the original one. The remote still doesn't work and I don't know what to do. I have an MXQ pro 4k s905 p201 distributed by Zenoplige. Can somebody help me ?
Thanks you! That is what I could not figure out. "Ugoos" who would have thought.... However, now that i can finally copy and paste and overwrite files, it still does not make the remote work. I think i'm same boat as you and we have a funky version of the remote that just dosn't work with these files.
Now that you have root access and you can edit and delete system files, there's nothing that prevents you from doing this.
If you really want to toss the box and give up on it, I'd be happy to buy it off of you.
There are currently 2281 users online. 1 members and 2280 guests.
