[ROM Image Firmware] MXQ PRO 4K - p201 - android TV (ATV) - by cOOLio
Originally posted by saulo View PostSorry, I have found the trick. But now I have this problem.
Have you solved it yet?''
Does anyone out there have a solution.?
I have tried the Coolio provided Amlogic burning tool .2.0.7.2. then also tried the 2.0.5.15 and the 2.0.8_x86 and a "new Usb burning tool" from entertainment box - which turned out to be another 2.0.8 . all stop on the erase bootloader.
when I unclick erase bootloader I get error IDENTIFY DDR USB CONTROL SETUP
Anyon have any ideas on this before I tear the rest of my hair out?
Originally posted by george1 View PostI have tried the Coolio provided Amlogic burning tool .2.0.7.2. then also tried the 2.0.5.15 and the 2.0.8_x86 and a "new Usb burning tool" from entertainment box - which turned out to be another 2.0.8 . all stop on the erase bootloader.
Please please please i need help I installed this system On my BEELINK M18 TV BOX And it works But not working me no internet no wireless internet and no remote control Please port it To my device or help me fix this https://www.entertainmentbox.com/bee...ware-download/
I'm currently using a mouse
My problem is my remote that comes with the box doesn't work.
I did manage to backup my stock rom/original remote config file and it somewhat works. The volume up and down don't work, the Enter/OK button in the middle doesn't work, the back and home doesn't work.
Through trial and error I did find the enter/ok button and the back button which is #5 on my remote for some reason.
My original stock rom is NEXBOX 5.1.1 MXQ PRO 4K.
I will provide some files now.
My original remote.cfg
Code:#********************************************************************************************************* #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************************************************************************* #amlogic NEC remote factory_infcode = 1 factory_code = 0xfe010001 work_mode = 0 repeat_enable = 1 repeat_delay = 40 repeat_peroid = 39 release_delay = 121 debug_enable = 0 fn_key_scancode = 0x00 left_key_scancode = 0x51 right_key_scancode = 0x50 up_key_scancode = 0x16 down_key_scancode = 0x1a ok_key_scancode = 0x13 pageup_key_scancode = 0x04 pagedown_key_scancode = 0x1b mouse_begin 0 0x51 1 0x50 2 0x16 3 0x1a mouse_end key_begin 0x41 113 0x10 114 0x18 115 0x51 105 0x16 103 0x50 106 0x1a 108 0x13 97 0x19 158 0x11 172 0x40 116 0x4c 139 0x4e 2 0x0d 3 0x0c 4 0x4a 5 0x09 6 0x08 7 0x46 8 0x05 9 0x04 10 0x01 11 0x42 14 0x0f 392 0x43 141 key_end repeat_key_begin 0x41 113 0x10 114 0x18 115 0x51 105 0x16 103 0x50 106 0x1a 108 0x13 97 0x19 158 0x11 172 0x40 116 0x4c 139 0x4e 2 0x0d 3 0x0c 4 0x4a 5 0x09 6 0x08 7 0x46 8 0x05 9 0x04 10 0x01 11 0x42 14 0x0f 392 0x43 141 repeat_key_end
Code:0x05 15 #Enter #oldback 0x54 6 #Back #oldNo.5
I would appreciate any help.
Originally posted by krappa View PostMy problem is my remote that comes with the box doesn't work.
I need your help guys. I dont get my Remote working after flashing Coolios Firmware.
My Board is a MXQ S905 V2 20151112 1G/8G with a RTL8189ETV WiFi
I searched and read all i could find. Even tried various remote files (but it is never clear from which remote/box exactly it was).(stupid me that i flashed new firmware before i saved the remote configs)(i found a hint to the original Firmware - but i suspect it wasnt as there the remote doesnt work too - as well as the LED Color behaviour since i flashed Coolios)
i attach some pics of my Board and remote. May be anybody has fitting files for me.
btw Thanks Coolio for the new Firmware. with exception of the LED Color (only blue instead of red and blue) it runs fine. May be you could find time and update it a bit and tweak it a bit more if possible
There are currently 2481 users online. 5 members and 2476 guests.
