J22 TVSTICK with AP6210 wifi
    I have tried to get the Stock ROM and kernel but its very difficult to get it seems. I have also tried MK908 strauzo kernel With both Finless 4.2.2 and T428 Nexus sdk2 ROM. No Luck still dead Wifi and BT. In the description link for the CX919II it says "Linux kernel 3.0.8+"? http://www.aliexpress.com/item/Mini-...925745462.html
      J22, DM918 and CX919II its all the same units. I have located the manufacturer which is Shenzhen ENY Technology Ltd. They said they will send me the Stock rom and kernel tomorrow for CX919II. I really hope this will fix the problem.
        hope
        so there is hope to get it working again
        please post it here when you get the firmware
        cheers
          Here are my thinking of the Problem:
          We have so much Quad Sticks with the AP6210 Wifi Bluetooth Stick out and when we try changing the Firmware with another with the same Chipset it not Works.
          I think i know why, this Chips needs Firmware to Work right. My thinking is when they make this Firmware for these Chips that´s they only Working in a Specific Stick and Wifi Chip with the same ID ?
          What do you think ? Make Sense isn't it ?
          Neomode
            Yes it must be some kind of pairing between the chip and the firmware maybe?
              cheers
              Will do
                AW: J22 TVSTICK with AP6210 wifi
                Yes that's what I mean. The WiFi Chip need micro code to operate and I think there is something like a protection inside. Make sense ?
                  Yes that make sense, a bit strange since I have not seen that before Lets hope the the stock firmware solves the problem
                    Okey they have not sent me the firmware yet. I have to wait 2 more days they say.
                      New recovery software CX919II, M918, J22
                      After two days of intense searching for the right firmware I finally got it!!!!
                      Here it is:
                      Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
                      I used RK Batch Tool v7 (chinese version) to install.
                      It might take a little while the first time you start up.
                      WIFI and BT working again! Still a bit stuttering on netflix and XBMC, so if anyone got a sollution to this problem I will even moore happier
                      Any questions please let me know! I am really happy right now!
                      Henrik
                        kernel
                        Would the wifi & BT be in the kernel ?
                        or could we flash the kernel from sam321 in it to solve the frame skips.
                        Neomode or sam321 do you know this ?
                          I am not sure, it seems it would be in the firmware, the only way I think would be to flash this and then only the kernel to try?
                            yes it can work to change the kernel.
                            but you must try it. the most time it work.
                            Neomode
                              I tried MK908 kernel at it didnt work
                                i think better is a mk802iv kernel for the new wifi chip.
                                neomode
