J22 TVSTICK with AP6210 wifi
    Originally posted by neomode View Post
    Yes we figured out how to read out the GPIO Pin´s.
    With that we can make a Custom Kernel :-)
    Neomode
    Thats awesome Neomode Looking forward to get this working as it should, Henrik
      Neomode
      Perfect, do you know if its possible to make it compatible With 1080p kernel? Thanks Henrik
        Neomode
        Hi neomode,
        First of all thank you very much for your hard work
        I recently bought a diferent stick (http://www.aliexpress.com/item/New-I...014053326.html) but I am using the same cyxtech ROM refered by mrlaban (The wi-fi is working)
        Do you think that the custom kernel that you are building will also work for my device?
        Regards
          News?
          Hi Neomode,
          Are There good News, about j22 custom rom?
          I would know if i can help you with something.
          regards
            AW: J22 TVSTICK with AP6210 wifi
            Yes, can you gave me the original Kernel.
            Or have you a link to the Original Firmware ?
            Neomode
              Here you are Neomode,
              In this page you can found it,
              http://androidpc.es/blog/2013/08/01/stock-firmware-para-tv-stick-quad-core-j22/
              or Here is the direct link.
                Hi neomode,
                how is the custom rom going?
                Regards
                  Yes it will come. I see a light we have a custom kernel and Bluetooth work. Only must fix WiFi.
                  Neomode
                    neomode any new happy news?
                    on J22 only original rom works with wifi and bt
                    no other one works...altough they are made for ap6210
                    good work mate
                      When we have the Custom Kernel all will be ok.
                      The issue with not working Wi-Fi and Bluetooth comes from the Kernel.
                      Because they use a different GPIO Ports inside the kernel to switch on Bluetooth and Wi-Fi.
                      Neomode
                        hello
                        i made gpios dumps (attached) so i hope from this you can compile a kernel with working wifi and bt for j22
                          Great thank you!
                          Neomode
                          Send from my Mobile
                            wow
                            you check forums when you sleep also?
                            that was fast...
                            great neomode
                            p.s. i also sent you PM as i didn't know you would see this...
                              Yes I always check The Forum for new messages :-)
                              It is the first what I do in the morning after waking up. Right now my time is 06.50 PM. So no sleep right now ,-)
                              Neomode
                              Send from my Mobile
                                it's same here
                                germany - slovenia (same time...)
