J22 TVSTICK with AP6210 wifi
Originally posted by lonely2k5 View Postok i made some roms...wifi and bt are working
try base if you have black screen or stripes..if it works try other (tweaked)
p.s. i have more tweaked kernel - antutu - 19.800 no problems...
I have tried all tweaked kernels - everything works just fine. Antutu up to 19300. WiFi + Bluetooth - works without any problems. Great work! Thanks a lot!!!!
How did you manage to get Antutu 19800?
vitaliy0099
i have restarts in antutu if i power the stick from laptop usb...when i change it to ipad power supply all works to 100%
Booxtor
i made a special kernel (twaked)...cpu OC 1800, GPU OC, DDR OC
it gets a bit more hot that other kernels but haven't had problems...but to be shure not to burn something i use CPU version and that makes antutu 19300
Rawie
try to reflash everything...first erase then reflash ROM and kernel
i have tried your kernels, but i get Antutu max 17.900 after erase idb and flashing Neomode rom 1.7
how is it possible? can you check attached screenshot what part is a Problem?
Thank in advance.
Originally posted by lonely2k5 View Postvitaliy0099
i have restarts in antutu if i power the stick from laptop usb...when i change it to ipad power supply all works to 100%l
I'm using power suply (2Amp) but I'm not sure because (made in China)
I returned back to kernel ( kernel_j22_720p) and antutu test 18348 but second test was 18641
and other couple of tests were ~186**
Great kernel. Thanks a lot.
Originally posted by lonely2k5 View Posthere is my test from currently installed kernel
if i compare i get 100 more in every test, but most in 3D
thanks for your Answer
I have your kernel kernel_lon_720p_1.6cpu_v2_ddr.img.zip
What Kernel are you using to get your Score. Can you post this Kernel?
When the Kernel is the same like mine, must be something wrong with my Stick
Could you do please tweaked GPU OC kernel for my stick to get better score in 3D?
I would like to play same Games with my Son.
Thanks man
Booxtor
Rawie
Originally posted by lonely2k5 View Posthi
this one i currently use...19.600 antutu...no overheat
i tried to OC gpu but the smallest OC of GPU it gets unstable and also lines most of the time...so i don't recommend it
try this one and report...
for XBMC users...i have problem with alpha9, but alpha8 is ok
i have tried your kernel, so far good. but the stick in Asphalt 8 was going to overhead.
antutu restarts by testing cpu.
gpu was just 2300.
there is something wrong with my stick.
where exactly have you problem in alpha9, on my stick everything smooth so far in alpha9.
Hello lonely2k5
Thanks a lot to YOU for your ROM
I have installed NHR1.7 + kernel_lon_720p_1.6cpu_v2_cpu.img.zip
it work fine,but i can not mount USB disk
hi... i have a new j22, it arrive now from china.
i try to flash stock rom from geek... but it not work....
after i flash neomode 1.3... don' t work
after i flashed neomode 1.7 , it work.. but i no have wireless and bluethoot
after i flashed neomode 1.7 and lon 720base and 1080base... no work... no load, and if load the screen go crazy... i cannot test if wifii work
after i flashed neomode 1.7 and origina kernel.. no work
so... i post its original kernel and boot..
for lucky i make a backup before with dump_image
if you can do somethings :-)
the chipset is 6210
UPDATED:
i use the kernel_lon_720p_OC_DDR_CPU and all work! wii.fii and bluethoot are ok
1) the app Tincore crash every time i launch it.... but for me it is no a problem
2) sometime the screen became all black for one/two seconds... but after it work again,
as it go in suspension mode.... audio and screen go out for same seconds...Attached FilesLast edited by angelobiz; 08 November 2013, 00:31.
There are currently 1883 users online. 0 members and 1883 guests.
