J22 TVSTICK with AP6210 wifi
Sorry too much work as a hobby. I've spent probably ten man days getting the KK kernels working for tv stick and box and now focussing on tablet.
HOWEVER, leolas can build jb stuff and there's the automatEd Marvin tool
Using my ipad so apols for any stupid ios spelling 'corrections'Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Best KK ROM for J22?
Hi Guys,
D33 , Finless , or other specialist ROM cooks
What would be the most stable and best KK ROM + Kernel for the original J22 ?
I'm still on 4.2.2 now but it's time to flash
my J22 isn't modded, so standard 1.6 Ghz is ok
main use: Video playback (archos/xbmc) via Wifi (1080p if possible)
Thanks in advance.
Renzo
Hello,
I've bought second CX919II identical to my first one. I had perfect combination of kernel, system image with everything working.
However, after trying to flash new device with same software it has some glitches. Part of screen is shaking every few seconds, sometimes system hangs and restarts.
Flashed first device with the same configuration - works just great.
New device - http://www.aliexpress.com/item/googl...117535857.html
Old device - http://www.aliexpress.com/snapshot/292002511.html
Technical specifications looks the same. Has anyone had problems with new version of CX919II? Maybe there is some new chip inside?
I have also 2. My first is not flickering the 2nd is flickering with the same kernel. Download this official Firmware from Bluetimes and ur new stick will work without flickering. http://www.sendspace.com/pro/dl/7bzbci Or look it here. There u will find also vsync fix and OC: http://www.freaktab.com/showthread.p...-dan-Vsync-Fix. I think the difference between ur 1st and ur 2nd stick is, that the 2nd stick is working with rk 3188-T cpu.cx-919ii
Originally posted by adamoz View PostI will have a few more of these J22's within days, I really think its best not to touch them and just root the stock ROM
Problems with netflix switching resolution solved
Originally posted by lonely2k5 View Post
I tried installing a enhancement on the xda forum called comadose, and presto, everything is faster and no jags at all on netflix. locks in to hd instantly.
here is the link:
4.4.2?
this is still Android 4.2 ?, I want 4.4 on my J22 (it's a lot smoother)
what's your antutu score?
Originally posted by mikeopi View PostI have tried many different kernels and rom combinations and settled on the above combination of marvin kernel and cx-919 stock for the J22 stick. XBMC, crackle and many others apps worked fine at 1080p, However none of the roms played netflix correctly. Netflix would bump down to low resolution despite a fast wifi connection.
here is the link:
http://forum.xda-developers.com/show....php?t=2419255
Kit Kat 4.4.x! Here we go
If u want to update to Kit Kat 4.4.x without bricking the device, you should follow this link
http://www.freaktab.com/showthread.php?11540-cx-919ii-Bluetimes-BT919-GM282-DM-918-etc-updatable-to-Kit-Kat-4-4-x-without-bricking-the-device!!!
Max Onecx-919ii
Well working cx-919 II with rom but no fast wifi on N band
I followed all your suggestions and am able to have a well working stick with kitkat.
Only problem is that if my router is in mixed mode (b/g/n) or
in n mode the stick has a download speed < 1Mbps.
In b/g mode it has around 18 Mbps which is fine if I compare it
with my phone.
Don't like to put the router in b/g mode.
Any suggestions?
Thnx!
I purchased the 919 II from aliexpress. Its locked at 1ghz and can not show even 720p or above.
WTF is going on? I am really pissed and just don't get it at all. What speed were your units locked to on stock roms? I needto do something to fix this stick! Help someone please :O)
There are currently 3486 users online. 0 members and 3486 guests.
