J22 TVSTICK with AP6210 wifi
    mk980 III no wifi and no bt
    Dear all, hope to be in the right place, to post my problem... After reading hundreds of pages here, I'm still not able to fix the issue with the wifi (impossible to turn it on)
    Tried many roms, different kernels (I think the hw info for the wifi and bt chip are built into the kernel?)
    I contact the seller and he suggested to me to see a youtube video in which I found the link to this forum.
    You're my last possibility, I'm pretty sure I don't have the AP6210 WIFI CHIP built in, here the link to see the picture: https://www.dropbox.com/s/fddw45caxt...209_141123.jpg
    I don't know what to do, if there's any available rom and/or kernel working with my wifi chip... (supposing that is the problem)
    I really hope in you all.
    Regards
    Riki
      Hi guys, bit of a noobie question here. Have the J22 too and I want to check its hardware specs. How to safely pry open this bugger? don't want to wreck the casing
        Just pry it open with a wide, flat blade screwdriver. Be careful not to lose the Fn button cover.
        MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
          I'm trying to put compile flags in to my code to make building kernels easier.
          The KitKat (4.4.2) kernel attached should provide:
          1. AP6210 support for J22 and equiv.
          2. 1920x1080 default resolution
          3. 1.8 GHz (RK3188) or 1.4 GHz (RK3188T) max. CPU
          4. Identify CPU and put message in DMESG log
          I'm worried that I haven't got the BT bit right so would appreciate some feedback.
          NB. for use with KitKat ROM only!!!
          Donate to Finless
            Is it possible to get kitkat rom for CX919II somewhere?
              Im also confused. Is there a better ROM than the stock to use on this? I just need 720P I dont want to overclock but rooted and the tweaks that ROM cookers make to the Governor's + init.d and debloat etc is what im after.
                Hi
                I hope you can help me, i am trying to get a working ROM for my Stick since 2 days !
                My hardware is an RK3188-T with an AP6210, 2GB RAM und 8GB Flash, according to the seller the stick is an MK809III/J22.
                Marking on the board is cyx tech rk3188 909 v1_1
                I have tried many ROMs and kernel from Neomode and others from this thread but all ROMs makes the same problems,
                the screen flickers more or less !?!
                I will not oveclock the device.
                  Originally posted by reno73 View Post
                  Hi
                  Hi if you will not overclock the device why do you want a custom ROM? is it to use game controllers etc? I have tried a few ROMS and just had problems.. I went back to stock and have rooted the stock ROM, wifi is good 64mbit no drops, I wanted a ROM as these guys usually put in a few init.d scripts and some "V8 supercharger" or the latest tweaks to get these stick running much better.
                  What I will do is post back my results in implementing a few tweaks. If anyone else knows a few of the good standard tweaks pls post
                    I will not use the device for special things, no game controllers etc.
                    I will use it for internet searching, youtube,..
                    The custom rom is this http://pan.baidu.com/s/1ntFKY5j
                    What i have to do to "repair" the flicker ??
                      I somehow managed to screw up its 5v power input port (bit askew).. I'm glad you can power up via the OTG port as well
                        After a vew days of experiments with many, many ROMs, a information for someone bought this stick (i am too)
                        http://www.****.at/itm/281240926401?...84.m1439.l2649
                        A working ROM for this stick (MK809III/J22 with RK3188-T and AP6210) is there
                        WLAN, Bluetooth, Ethernet Stick OK
                        And NOOOOO flicker
                          Hi guys,
                          Is it normal that my CPU is locked to 1200mhz and that the device is recognized as a Samsung GT-I9300 after I flashed this rom?
                          I do have a CX 919 II and the stock rom I got gave me a lot of problems with apps. Those problems do seem to be fixed with this rom.
                          Best regards.
                            1.2 GHz is slow, even if you have a 3188T.The Samsung device ID is normal for the Finless ROMs.
                            Sent from my Nexus 7 using Tapatalk
                              New KitKat kernels click here
                              Compiled for T / non-T and with optional 1.8V lcd setting to stop flickering
                              Donate to Finless
                                THANKS
                                Might giv'em a try tomorrow
