J22 TVSTICK with AP6210 wifi
no.. whit oc kernel i have only black screen for few second.... it is very bored... you cannot do nothing,,, it is impossible see a movie or hear a song... :-(
i note a things,,,
stock firmware of J22 cyxtech_rk3188_dongel_ap6210_130629_EN no work,, tv stick no boot!!!
so maybe it is a littlebit different....
@rawie if you want i can upload a backup of stock firmware that i make with dum_image
Originally posted by angelobiz View Postno.. whit oc kernel i have only black screen for few second.... it is very bored... you cannot do nothing,,, it is impossible see a movie or hear a song... :-(
i note a things,,,
There were at least two versions of that stick. Are you sure your is version with the AP6210 chip?
All CX919 II (j22) sticks in my stock work with the stock firmware (cyxtech) or with the new kernel of Lonely25 and hybrid firmware of Neomode without any problem.
i have 6210 chipset...
my stick don't work with J22 cyxtech_rk3188_dongel_ap6210_130629_EN, tv stick no boot!
if i use hybryd 1.7 or 1.3 with lonely kernel... it boot... wireless e bluethoot work... but i have a black scree sometime.... and display fliker
i note one things...
if i set screen to 720x576.... all work .. i no have more black screen....
so i thinks that the problem is on 1280x720 or 1920x1080... if as the stick set by self the resolution so i have back screen for same second...
i try su different tv and with different power supply...
Maybe a 3° version?
i have posted my stock kernel and boot... if someone can see inside them :-) :-)
i have more stick... and all same stick have same problem with black screen
i note a things,,,
and we have same version... :-)
i'm uploading it...
it have parameter for 4gb for app and both loader 1.20 and 1.24
you can use flash of finless rom
here:
Originally posted by lonely2k5 View Postangelobiz
if wifi and bt works then kernel is ok
my kernel is changed only in wifi and bt settings, otherwise its the same for all sticks
did you tried all versions of my kernel?
if i use the 720 resolution i no have problems....
only if i change resolution to 1280 or 1920 i have frequently black screen for few second...
today i use my stick on old plasma tv.. and in it work good...... but if i try same stick on my new tv... i have random black screen.... ( the styck is always on)
it seem tha tv try to setting always the resolution
i don't know how i must think :-) ....
because with the original stock firmware of J22 my styck don't boot... i thinked that they was a little bit difference...
Originally posted by angelobiz View Postand we have same version... :-)
i'm uploading it...
here:
https://mega.co.nz/#!c8sGDbxD!EmffgR...FffI4XT3i2ridU
Originally posted by lonely2k5 View Postok i made some roms...wifi and bt are working
try base if you have black screen or stripes..if it works try other (tweaked)
I'v flashed your kernel_lon_1080p_1.6cpu_v2_base with neomode 1.3 rom. WiFi and Bluetooth are working now. System looks stable. That's great.
Minor problems are with graphics - in WiFi spped test application some big black squares instead of speedometer arrow - which was not the case with stock rom.
The only real general improvement would be HDMI audio pass trougth (like one available on CS968).
It would be really great if you publish source or just changes to thesawolf kernel which you used as a base. All here who want to try adjust the kernel will be wery gratefull to you not to spent time to repeate GPIO stuff you'v done already.
Originally posted by lonely2k5 View Posthi
this one i currently use...19.600 antutu...no overheat
i tried to OC gpu but the smallest OC of GPU it gets unstable and also lines most of the time...so i don't recommend it
try this one and report...
for XBMC users...i have problem with alpha9, but alpha8 is ok
can you please post here the same kernel but OC to 1.8? Thanks in Advance
There are currently 1994 users online. 2 members and 1992 guests.
