J22 TVSTICK with AP6210 wifi
    Originally posted by lonely2k5 View Post
    djaladin
    the kernel is 1,7 overclocked, i'll make you 1,6 kernel and try it if it's more cold
    EDIT:
    kernel 1.6cpu added
    thanks for kernel_lon_720p_1.6cpu, so far it is working great (using Neomode Hybrid Rom 1.7).
    But bluetooth doesnt work (Wifi does). In the settings dialog bluetooth can't switched from off to on.
    With the stock ROM Wifi and BT works, but video playback stalls.
    My board should be a J22 aka CX919II aka GM282.
    It says:
    2013-06-17 CYXTECH RX3188 Model 909 (8GB Flash, 2GB Ram)
    V1_1 - WIFI AP6210
    Brought a week ago from ereader-store dot eu.
    Has anyone the same problem?
    Thanks to Neomode and Lonely, I appreciate your work very much.
    Donation...done.
      perun
      bt should work...just turn it on, on the left side in settings menu
        Its not working for me, i keep getting stripes in the screen and keeps going blank. Tried all the kernels.
          Maybe we have 2 Hardware Versions out there. Wich Rom you use?
          Neomode
          Send from Mobile
            Neomode
            Send from Mobile
            I'm using NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
            and tried all the kernels, keep getting the same problem. Stripes in screen, and the screen keeps getting blank.
              perun
              Ok..I flashed the stock rom "cyxtech_rk3188_dongel_ap6210_130629_EN.img" again. BT, WIFI works.
              Next test: I flashed Neomode Hybrid Rom 1.7. Before flashing i did an "EraseIDB" -> BT, WIFI doesnt work.
              Next test: I flashed Neomode Hybrid Rom 1.7 with kernel_lon_720p_1.6cpu. Before flashing i did an "EraseIDB" -> BT doesnt work.
              Neomode should be right, there should be different hardware versions out there.
              For stock from see thread http://www.freaktab.com/showthread.php?7575-ROM-CX919II second post.
              Thanks for your help!
                Neomode
                Send from Mobile
                Hi Neomode,
                you have the same hardware version of J22 (or CX919II, which I've sent to you some weeks ago) as offered in ereader-store.de .. I know it because I am owner of this store.
                Unfortunatelly BT does not work in your new ROM /kernel. Everything else is OK.
                With the stock firmware I had some Skype connection problems. This was the reason I asked you for help. Now it seems that Skype has fixed this bug and after update it works in the stock firmware too.
                I just wanted to say thank You guys for your great work !
                  i'll try BT again...probably kernel error...i don't use bt so i didn't test it enough it seems...
                  will repair it ASAP
                    Think this is a GPIO error in the kernel.
                    Should be a easy fix.
                    Neomode
                    Send from Mobile
                      yes fixing it now...
                        How about the problem i'm having with the blank screen.
                          ill try to reduce some tweaks but could be hardware (try powerfull power supply)...i never had black screen...
                            I keep getting green stripes in the screen and also flickering
                            images. But on a different tv i keep getting black screens
                            after the stripes, didnt had the problems with the stock firmware with
                            same power supply
                              ok i made some roms...wifi and bt are working
                              try base if you have black screen or stripes..if it works try other (tweaked)
                              p.s. i have more tweaked kernel - antutu - 19.800 no problems...
                                Hello lonely2k5
                                Thanks a lot to YOU for your hard work.
                                I have installed NHR1.7 + your last kernel_lon_1080p_1.6cpu_v2_base.img.zip
                                All of them are working great
                                Only one problem is a test antutu. 8% and restart. I tried many times,
                                the stick is not too hot.
