J22 TVSTICK with AP6210 wifi
    Try it with this Rom Please --> http://www.sendspace.com/file/t4qx4e
    Neomode
      Neomode
      Hi Neomode,
      I have tried your linked IMG. Unfortunately WiFi does not work in this version on my device (J22 or CX919 II with A6210) .
      The only disturbing thing on this tv stick is not working Skype (camera works but I could not establish a working connection)
      This kernel I have extracted from original firmware and it did work in the combination with T428 Nexus SD2 update. But I couldn't notice much improvement and turned back to the original.
      If I give you a such a device (for free of course) could you possibly check if it is possible to do something with that issue? I bought it for my mother to allow her to communicate with her sister in other country, but without Skype it is not a proper gift for her.
        Have sent you a PM !
        Neomode
          Neomode
          Thank you Neomode I will give it a try, but I do not think it will work because there is some really strange things going on with this device mrlaban
            Its not working so I am back on my old MK802 which has no problem playing XBMC or netflix.
              Hello,
              I will get a J22 TV Stick in a few Day“s. Then i Start to make Devoloment to this thing.
              Neomode
                Hello,
                Neomode
                Thank you so much Neomode, you are the king!
                  Dem kann ich mich nur anschließen!
                  I can only agree!
                    @ neomode:
                    Kannst du das ROM so modifizieren, dass sich der Stick als Smartphone identifiziert?! Es hat sich gezeigt, dass manche Apps nur daher nicht mit dem Stick kompatibel sind, weil er sich nicht als Smartphone gegenüber dem Store identifiziert.
                    Can you modify the ROM so that it identifies the stick as a smartphone? It has been shown that some apps are only therefore not compatible with the stick, because it does not identify itself as a smartphone on the playstore.
                      Yes i can do it. No Problem.
                      Ja werde ich machen kein Problem.
                      Neomode
                        Super!
                          Neomode
                          Any News on this neomode?
                            AW: J22 TVSTICK with AP6210 wifi
                            Work on it.
                            Neomode
                              Work on it.
                              Neomode
                              Any update on the rom/kernel Neomode? Henrik
                                Yes we figured out how to read out the GPIO Pin“s.
                                With that we can make a Custom Kernel :-)
                                Neomode
