MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
    A big thank you! FadeFX
    Bonjour! Je suis de Shawinigan, Québec, Canada
      Question
      I have a MK908 unit which I installed this Firmware for and currently after the flash the unit will not boot. It will show GOOGLE TV for about 5s sec and reboot.
      The only way I get this unit to boot in using update_mk908_106j2107_04
      I would like to use this firmware due to the fixes and would like to use XBMC on this unit.
      Can you please help me?
        Using an MK908v1 and having trouble with virtual touchscreen input in Sixaxis. Does this ROM require the same type of fix as added in Finless 1.6a? Can the same update.zip be applied? If so, how do I trigger the update?
        DD
          DD
          the update zip worked a treat for me on my cx919 on finless 1.6b,dont no if it will work on this rom but cant see why not..once the update zip is on the sd card it updates its self on a reboot & when its updated delete the update zip from the sd card
            I placed the update.zip as the only file on a MicroSD, powered down and inserted it in my MK908v1. I restarted and during the boot process there was nothing to indicate that an update was being applied. Once it got to the desktop, I checked and the update.zip file is still on the MicroSD. I don't think it picked it up.
              AW: MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
              I guess u need to put it on internal memory (sdcard) not external (ext-sdcard)
              _________________________
              tapatalked from GalaxyS3
                hey anyone, when will finally done HFW 2.0.3 for MK908 v5? I need support to my gamepad xbox360, but by adding in /system/lib/modules xpad.ko and next using insmod xpad.ko it's no working, help please!
                  Hi.I got X5II. Can I install this rom into my device?
                    same problem, doesn't work with me..
                    anyone, help please..??
                      MK908v5 Support
                      Hello Lewy,
                      could You please update Your Rom to support MK908v5 Hardware?
                      Thank You and best regards,
                      Danta.
                        I have tried this and other ROM for my MK908 v3, but all are booting into recovery ??
                        What's wrong ?
                          rom doesn't support the MK908 V3 to V5 lewy's focus is on other devices atm
                          current devices(rockchip sucks)
                          Hardkernel ODROID C1 running android kitkat
                          Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
                          rPi model B+ running nothing ... bricked
                            my Tronsmart mk908 v5 won't boot with this rom. i try all was possible. the flash complete successfully but nothing, no blue light and black screen
                            Help please port your good rom to v5 soon
                              Same problem here.. I am having problems activating bluetooth on Finless rom, so I'd tried this one on my 908v5. Didn't boot
                              I'd be thankful for an update.
                                tronsmart mk908v5 please Lewy
                                Since many users request rom for v5, add to 'to do list' asap please Lewy.
                                We are waiting for long time from now
                                Thx for all your others greatest rom that you build. i know your good work been done, specialy on mk808/mk808b
                                Regards
