MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
Originally posted by Moulin1980 View PostHi neoal, in boot recovery, install via zip file, link :
http://download.chainfire.eu/351/Sup...etrieve_file=1
Droidmote
Currently running on the t428 the beta with both resolution kernals. the same problem persisted when i was running last week the stable 720
Can't get droidmote to work. Back button works, it says its connected just the mouse isn't there at all.
Probably a nube problem, Please enlighten a nube. Nice software BTW. fast and stable (at least with the ethernet)
Additionally: when I shut it down it boots back up. Could this be caused by the ethernet to usb converter i have in my hub, also the hub is a new thing to me, could that trigger a restart?
Re: MK908/T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
Can any of you T428 folks tell me how well Netflix works on the 2.0.3 ROM? I have been looking for a ROM that will run Netflix and OpenVPN reliably.
Waiting for the MK908 (v1) version of 2.0.3 but just curious if this combination will work any better than previous ROMs.Last edited by DigiDAD; 25 September 2013, 19:48.
Originally posted by Jorryt View PostIs there already a version for the MK908v3?
The only (a bit) working rom for me at the moment is: update_mk908_106j2107_04 from geekbuying. All other ROM's don't work. Even the stock roms dont work!?!
The file "mk908-HW_V3-jjhkernel-v5.1-400mhz-720p.img" works perfectly for me.
Originally posted by DigiDAD View PostCan any of you T428 folks tell me how well Netflix works on the 2.0.3 ROM? I have been looking for a ROM that will run Netflix and OpenVPN reliably.
I would like to know too... Netflix runs fine on Version 2.0.3?
it happens from time to time:"Everything is possible if we work together!
Originally posted by Molle View Post
There are currently 6257 users online. 3 members and 6254 guests.
